Bosch 1199VSR Chuck Removal
Snort | Posted in Tools for Home Building on July 20, 2009 11:11am
I’ve got a Bosch 1199VSR hammer drill, and the chuck is slipping with masonry bits. Which direction, from the front of the chuck, do I spin it for a removalectomy?
www.tvwsolar.com
We’ll have a kid Or maybe we’ll rent one He’s got to be straight We don’t want a bent one He’ll drink his baby brew From a big brass cup Someday he may be president If things loosen up
  1. Snort | Jul 21, 2009 02:32am | #1
    bumpity
    http://www.tvwsolar.com
    We'll have a kid
    Or maybe we'll rent one
    He's got to be straight
    We don't want a bent one
    He'll drink his baby brew
    If things loosen up
  2. FastEddie | Jul 21, 2009 03:49am | #2
    One might consider that as the drill rotates in the normal direction it is tightening the connection.
  3. bldrbill | Jul 21, 2009 04:38am | #3
    I don't know if this applies to Bosch, but my B&D has an allen screw in the bottom of the chuck that holds it on.  Open the chuck all the way and look down in there.
      IMERC | Jul 21, 2009 04:41am | #4
      and it's a left hand thread...
      WOW!!! What a Ride!
      1. rez | Jul 21, 2009 08:32am | #5
        Those little drill bits can be hell iffin you let them seat on that allen screw.
        Don't ask me how I know this
        1. Snort | Jul 21, 2009 02:20pm | #6
          No screw in the bottom. There is a hole in the housing for a shaft locking shiv. With no screw, I am assuming it was put on with some force... and I've gone the wrong way before<g>http://www.tvwsolar.com
          We'll have a kid
          If things loosen up
            IMERC | Jul 21, 2009 09:53pm | #7
            verify that the screw is missing or if it is broke off....
            WOW!!! What a Ride!
            IMERC | Jul 21, 2009 10:10pm | #8
            the chuck shaft is RH thread...
            put a reallllllllllllly big allen wrench in the chuck by the short arm...
            smack the allen wrench's long arm with a BFM or a DBH...
            takes gorilla to get to come loose..
            WOW!!! What a Ride!
          3. Snort | Jul 22, 2009 12:04am | #9
            Good idea on the allen wrench... I already busted off the chuck key LOLhttp://www.tvwsolar.com
            We'll have a kid
            If things loosen up
          4. Snort | Jul 22, 2009 12:11am | #10
            So smack it clockwise?... I'm left-handed, never can get it right, hahttp://www.tvwsolar.com
            We'll have a kid
            If things loosen up
          5. ClaysWorld | Jul 22, 2009 12:44am | #11
            Righty tighty Lefty losey but if your in Japan nevermind.
            Me be thinking clockwise and a pipe wrench and a sharp crack of the bfh.
            And that be looking down on the chuck from USA cause I don't speak forn
          6. Snort | Jul 22, 2009 12:58am | #12
            I'll print that out and take it to the shop, thanks<G>http://www.tvwsolar.com
            We'll have a kid
            If things loosen up
          7. User avater
            IMERC | Jul 22, 2009 03:38am | #15
            counter if yur looking at it straight on...
            WOW!!! What a Ride!
          8. User avater
            IMERC | Jul 22, 2009 03:44am | #18
            go get a nut and bolt...
            pretend the bolt is the drill's shaft and the nut is the chuck...
            WOW!!! What a Ride!
          9. Snort | Jul 22, 2009 02:09pm | #20
            pretending is one of the things I do best LOLhttp://www.tvwsolar.com
            We'll have a kid
            If things loosen up
  4. ClaysWorld | Jul 22, 2009 12:59am | #13
    I took a look
    http://www.boschtools.com/Service/ProductServices/Pages/ManualsandDiagramsResults.aspx?type=both&modelNum=1199vsr
    It always amazes me how slow the bosch servers are. You would think they should be on top of that.
    Not sure if this wil post but the drill display pdf shows no screw.
    File format
    1. Snort | Jul 22, 2009 01:30am | #14
      There is no screw, and those I've dealt with in the past have all been reverse threaded. Pretty sure Marty's got it right, allen key and a BFH<G>http://www.tvwsolar.com
      We'll have a kid
      If things loosen up
        IMERC | Jul 22, 2009 03:40am | #16
        not BFH.... BFM or a serious DBH....
        WOW!!! What a Ride!
        IMERC | Jul 22, 2009 03:41am | #17
        the pipe wrench will distort that Rohmn chuck and then it will be a RAG and cut off wheel...
        WOW!!! What a Ride!
        coonass | Jul 22, 2009 06:05am | #19
        Snort,I took off one for a friend by grinding some flats on a bolt for the chuck to grab and using an impact wrench.KK
        1. Snort | Jul 22, 2009 02:09pm | #21
          Excellent!http://www.tvwsolar.com
          We'll have a kid
          If things loosen up
Grout-Free Shower Panels
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
