Toda while looking through a couple of online tool retaliers I saw something interesting. There was a Makita 15/16″ rotary hammer on sale for $179 but on another tool site there was a 1″ Bosch rotary hammer for $299.
Can someone tell me why there is such a difference in these two prices?
apples and oranges...
WOW!!! What a Ride!
seems a lot for a silly little sixteenth inch, eh?
Post the model numbers of the tools if you want a fact based comparisson on the diff in the specs
Guys, the model numbers were:
Bosch #112255VSR (1")
Makita #HR2470F (15/16")
There ain't a lot of difference except for the Bosch is a a D-handle. Makita does have a 1" D-handle but it isn't on sale right now, just the one above. Still in all, $179 for the Makita versus $299 for the Bosch.
so that was easy enough...
not the same animal...
Bosch is Heavier duty...
and the Mak is on the dicontinue list...
Germany vs China....
specs don't match...
Bosch as follows...
7.5 Amp; 0-1,300 RPM; 0-5,800 BPM
HammerHookâ„¢ allows quick tool storage during the job.
Multi-function Selector — 3 modes of operation, rotation only, rotary hammer and hammer-only mode
Vario-Lock™ positioning — rotates and locks chisel into 36 different positions to optimize working angle
Patented Rotating Brush Plate — Provides equal power in forward and reverse
Patented Cord Turret — 35° pivot for added flexibility and longer cord life
SDS-plus¯ bit system — tool-free bit changes with automatic bit locking, dust protection and maximum impact energy transfer rate
D-Handle design — Ideal for overhead and downward drilling applications
Variable-speed Reversing Trigger — For accurate bit starting as well as removing fasteners or bound bits
Integral clutch — helps minimize torque reaction
Specifications
Amperage: 7.5
Certifications: UL
Country of Origin: Germany
Impact Energy (ft. lbs.): 3.2
Length: 17-1/4"
Max. Hole Diameter in Concrete: 1"
Max. Hole Diameter in Concrete-Thin Wall Core Bit: 2-5/8"
Max. Hole Diameter in Steel: 1/2"
Max. Hole Diameter in Wood: 3/4" - 1"
No Load BPM: 0 - 5,800
No Load RPM: 0 - 1,300
Optimal Concrete Capacity Range: 3/16" - 5/8"
Rating: 120V
Weight (lbs.): 6.7
Makita as follows....
L.E.D. Light Illuminates Drilling Surface for More Accurate Work
3-Mode Operation: Rotation Only & Hammering with Rotation and Hammering Only
Powerful, compact, ergonomic design with padded grip and side handle for increased operator comfort
Recessed Lock-on button for continuous use "No Hammering When Idling" function ensures extra-low vibration under no load
Extended service life of carbon brushes
One-touch sliding chuck allows for quick and easy bit changes
Capacity
Concrete(with core bits)
2-1/8"
Steel
1/2"
Wood
1-1/4"
AMPS
6.7
No Load RPM
0 - 1,100
Blows/min.(BPM)
0 - 4,500
Length
15-1/2"
Net Weight (lbs.)
6.3
Impact Energy (J)
2.7
Your such a tool geek.Not that there is anything wrong with that.
thank you....
but isn't that what I said in this post????
Are you absolutely sure that model is made in China? Most of my Mikita tools are made in America In fact I've only got one (an illegal import) from Japan.
That is less consistent in the larger heavier tools. For instance, most Bosch named are made in the S Carolina Skil-Bosch plant, but the one mentioned is made in Germany
tool store site said the Mak was being dicontinued and made in China...
Looking for a rotary hammer- check Lowes - they are clearing out the Dewalt 1" d-handled SDS hammer 3mode for $135 - reg $269.As for tool prices - why be surprised at differences in pricing these days - that's why it pays to shop around...Julian
to me a a DeWalt for free is not a good deal...
Not much good to generalize with tool brands...They make some of the best routers, their chop saws are pretty nice and this particular rotary hammer is made in the EU - so it's got the same european origins as all of the other d-handled rotary hammers from other brands.I'll agree they make some pretty huge #### too - but aside from Festool or Hilti - find a brand that isn't making a few doggy doos in their lineup these days...JT
I don't much care for the company...
the company making/marketing the goods figures largely into the equasion...
BTW, the Bosch drill chuck you can buy to fit into the SDS holder is well worth the money. If you don't have your Hole Hawg on site, you can use the Bosch Hammer for your heavy duty drilling.
BTW...
the Bosch model number is 11255VSR
first thing Isee is you mention sale pricing. Lots of times a tool is on sale special price because it is about to be replaced by a newer model with more features. ( sometimes this is not so good - could be coming from an entirely different factory) That said, see that the Bosch is a higher amp tool. The amps is a good indicator of power available.
BTW....
ya need to shop at other places...
top one is reconditioned...
bottom one is new....
WOW!!! What a Ride!
