Bosch SDS Max: Will it handle it?
Ted W. | Posted in Tools for Home Building on June 7, 2008 04:35am
I’m looking at an older Bosch SDS Max, says it’s 1-1/2″ but that would just be the spiral bit capacity. I need to use a 3″ thick wall core bit. Will this tool handle it without burning out?
Cheap Tools at MyToolbox.net
See some of my work at TedsCarpentry.com
    IMERC | Jun 07, 2008 04:44am | #1
    suppose to...
    • Amperage: 10
    • Impact Energy (ft. lbs.): 5.2
    • Length: 17.25
    • Max. Hole Diameter in Concrete: 1-9/16
    • Max. Hole Diameter in Concrete-Core Bit: 4
    • Max. Hole Diameter in Concrete-Thru Hole Bit: 2-1/2
    • No Load BPM: 3000
    • No Load RPM: 400
    • Optimal Concrete Capacity Range: 1/2 - 1-3/8
    • Rating: 120V
    • Weight (lbs.): 13.2
    WOW!!! What a Ride!
      Ted W. | Jun 07, 2008 04:47am | #2
      Thanks.
      Just curious, what is a "Through Hole" bit?--------------------------------------------------------
      Cheap Tools at MyToolbox.netSee some of my work at TedsCarpentry.com
        IMERC | Jun 07, 2008 04:58am | #3
          Ted W. | Jun 07, 2008 05:17am | #4
          Ah yes, I've seen those. Never knew what they were called.
          I just won the eBay auction, got the drill for $180 + 30 for shipping. It's an older model but if it does the trick, I'm happy.
          Edited 6/6/2008 10:48 pm by Ted W.
            IMERC | Jun 07, 2008 08:06am | #5
            have it serviced before ya use it...
            Ted W. | Jun 07, 2008 12:15pm | #6
            Actually, I wouldn't have it serviced unless it really needs it. I've got tools I bought used years ago that are still running like new. But thanks for the tip.--------------------------------------------------------
            IMERC | Jun 07, 2008 02:26pm | #7
            if that tool lived a dismal former life it will need servicing...
            Ted W. | Jun 07, 2008 08:09pm | #8
            I understand that, but my drilling four holes to get a job done and get paid is no different than if the previous owner drilled the four holes. Also, the options at this time are between paying my auto insureance, phone bill, getting a 2" core bit to drill the holes, eating, or paying to service a tool that may or may not need it. I understand that it's important to take care of my tools, but paying $75 to $130 and waiting yet another week before I can finish the job just isn't an option. --------------------------------------------------------
            IMERC | Jun 08, 2008 12:54am | #9
            okay....
  2. renosteinke | Jun 08, 2008 03:41am | #10
    I hope so; my Harbor Freight SDS (a much smaller tool) has no problem with that size core drill.
      Ted W. | Jun 08, 2008 04:01am | #11
      That's pretty impressive for Harbor Freight. I've always looked down on their lesser quality products, but I keep hearing more and more about Harbor Freight tools being a decent bang for the buck.
      BTW, I've been googling and otherwise searching all over the web for information. It appears the drill in question will handle up to 4" thick wall core bits, and up to 6" thin wall. Assuming the tool is in decent condition when I recieve it, I think I'm safe. --------------------------------------------------------
      1. renosteinke | Jun 08, 2008 04:38am | #12
        It's a matter of your priorities. In my case, the cheap tool on the truck trumps the expensive tool at the supply house. Moreover, in using the cheap tool, I get a feel for how often I will use it, what features are desirable, and whether it's even worth having at all. As often happens, I end up using a tool a lot more often, once I have it. In this case, as soon as the HF dies, I plan to replace it with a better one - probably a Bosch!
          Ted W. | Jun 08, 2008 05:02am | #13
          Ain't that the truth!
          I have so many tools I needed "once". Suddenly I find myself reaching for it on a daily basis. Perfect example, my 18V impact driver. I figured I'd only use it when a phillips bit in the drill just won't cut it. But now, I don't remember the last time I chucked a phillips bit into the drill, and the impact driver found a permanant home right next to it in my canvas drill bag.
          I have an SDS Plus drill which might be able to drill the 2" holes, but I don't want to chance it. Also a good excuse to buy a new-to-me tool. --------------------------------------------------------
Picture-Perfect Pergola
