Bosch zero clearance insert.
webby | Posted in Tools for Home Building on April 6, 2008 12:26pm
Has anyone found a good aftermarket zero clearance insert for the Bosch 4000?
I have Bosch’s but that thing is so flimsy it is about worthless.
Any help would be appreciated. It really helps the dust collection with one in place. I spent the morning choking on mdf dust.
Webby
  1. mike_maines | Apr 06, 2008 12:28am | #1
    I made mine.  Took about 20 minutes with a jigsaw and a belt sander.
    basswood | Apr 06, 2008 01:25am | #2
    I made one for mine too...does help keep the dust down and cuts better and safer too.
      Sphere | Apr 06, 2008 03:31am | #3
      How thick is the Bosch?
      I use stop signs and lexan for some of the newer thin type of plates..I miss the old 1/2" thick plates of my old saw, I had a few for molding heads, and different dado widths out of Baltic Ply wood, but the newer saws are a pain being so thin.
      Street sign alum is awesome stuff, I always have  few hunks laying around the shop for jigs and templates.Spheramid Enterprises Architectural Woodworks
      "Welcome to Poo-ville, can I have your socks?Seriously Folks, I need a home for 3 lovers of your life.
        basswood | Apr 06, 2008 03:55am | #4
        The Bosch is a fairly thick plate, IIRC around 3/8"It has a few places on the underside that have to be mortised out to fit over some metal tabs and on the outfeed end it needs to key in under the table so it does not climb the blade and get hurled. I used a small dowel sticking out of the outfeed end of the plate to grab under the table.
          Sphere | Apr 06, 2008 04:30am | #5
          In my exp. ,thick is better for sure, I know of the dogs ( tabs) that you mean. They can be good for leveling screws to rest on, small allen set screws work good.
          Cheap stamped plates can't easily be leveled.Spheramid Enterprises Architectural Woodworks
  3. Barney | Apr 06, 2008 05:29am | #6
    A place that has had plenty of after mark zero clearance inserts previously has been http://www.woodcraft.com
    They might have one for you.
    Barney
    Its not the destination, but the integrity of the journey.
A New Approach to Foundations
