Bostich Nailer skipping / missing
gj13 | Posted in Tools for Home Building on September 13, 2009 12:42pm
I’m installing hardwood in our house (as per previous posts) and have a Bostich manual nailer, factory reconditioned. It worked perfectly well for a while. Now it’s missing the cleats if I hit it too hard. The only way it seems to work is if I tap it lightly so that it grabs the next cleat, then I can whack it. So it’s two to three hits per cleat. Not that it’s a real problem, but what’s wrong? Can I fix it?
  1. FastEddie | Sep 13, 2009 04:21am | #1
    Sounds like the nail feed spring might be weak or loose.
  2. CardiacPaul | Sep 13, 2009 04:27am | #2
    Magazine & feed spring may need lub to make the nails advance more freely.
    Best of luck
     No one should regard themselve as "God's gift to man." But rather a mere man whos gifts are from God.
