Bostictch gun misfire: Anyone?
Woodside | Posted in Tools for Home Building on January 19, 2005 05:11am
I have a Bostitch N88RH Framing Nailer. High Power, shoots round head, has tip for hanger nails. It’s about 15 months old.
I didn’t use it for 4 months. Today, in the very cold, I hooked up the compressor hose, and the gun fired. I disconnected it and reconnected it, and it fired again. Then I used it all day and it was fine.
This ever happen to anyone? Any ideas what’s wrong?
I thought of the o-rings, but if the triggers not being held, how would the ring make a difference?
Woodside
    IMERC | Jan 19, 2005 05:23am | #1
    time fer lub at least or O rings at worst in the trigger assembly...
    is the safty stuck???
    WOW!!!   What a Ride!
    IMERC | Jan 19, 2005 05:24am | #2
    you may have ice in the gun holding the trigger slave..
    the gun thinks you squeezed the trigger..
    WOW!!!   What a Ride!
      dieselpig | Jan 19, 2005 05:52am | #4
      I think you nailed it.... ice in the trigger slave.
      Four degrees this morning when I got out of the truck.  Same thing happened to one of my Hitachi framers first thing this morning when I plugged in.  Not that unusual in the cold and it was break your balls cold today.  Had to leave the Rol-air in front of the exhaust from the truck for about 10 minutes before I could even turn it over.  Left the truck running for most of the day thawing out subfloor adhesive.  Had 2 inches icicles hanging off the goatee 20 minutes after getting out of the truck.  Thank God for engine block heaters.
      Winter rocks.
        IMERC | Jan 19, 2005 05:56am | #5
        rig an insulated house fer the roll-air and put one of those little electic heaters in with it...
        put 5 or 10 weight oil in the compressor... non detergent...
        my Senco's will do that on sub-zero days....
        WOW!!!   What a Ride!
        Sphere | Jan 19, 2005 05:58am | #6
        you actually made sense of his post?
        better man...DP..better man...
        Watch out for the edges, it's really fast out there...
          IMERC | Jan 19, 2005 05:59am | #7
          take up learning to read 101...
          it'll help...
          WOW!!!   What a Ride!
  3. alwaysoverbudget | Jan 19, 2005 05:24am | #3
    i hate bostich just because of the misfires. if you need to shoot 3 boxes buy 4 so you can blow nails all over the job site.i have had them fire when the air  hits the gun,i don't know but i always figured the valve that lets the air into the chamber is sicky when cold and lets a blast of air into the chamber. just be careful with it and if somebody has a sale on a different gun and takes trades dump it. lol larry
