I’m needing the same thing. Found the parts diagram on the web but no How-To instructions. I got 2 so if all else fails the other one will serve as the blueprint to re-assemble the broke one.
I woudn’t say 175psi is regulated.
Not sure when they started it, but all their guns now have 7 year warranties.
JT
These are older than 7 years, probably closer to 15 but still working good. They were much more expensive then and the newer ones have some nice features but... they still work good.
I overhauled my bostitch finish nailer. IIRC there was an instruction sheet in the kit. As you take it apart line the pieces up on your surface as they go. Match the old rings and gaskets next to the new ones. Wipe excess dirt and oil off everything. (Man did I over oil!). It really was not difficult. Just don't take it apart and throw the pieces in a bucket.
Isn't 175 psi a bit high for a nailer?
Scott.
Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.â€
It's just beside the male coupling on the gun ,do not exceed 120psi and trust me that's enough trust me
