This is the almost finished frame for a 6′ radius curved beam. The verticals are placed to accommodate fastening 2 layers of 3/8″ ply for the sides. The sides were attached after placing the frame because I needed access to the interior for fastening to the posts. Just lifting this frame into position require two guys. If I had applied the skins it might have taken another two men and a boy. You will definitely need that extra boy to lift yours. It wasn’t practical (for me) to attempt to build the whole thing in place. Beam in position and skinned
Beam with stucco. The reason for the standard stucco is that it was much easier to finish the curve that if I used straight EFIS techniques. The EFIS adhesive base coat is normally no thicker that 1/8″ and applied to flat surfaces. You could do it curved but I just found this combination easier.
Traditional lime wash still has tons of useful applications.
yo Ralph, what's the green box and the pipe thing?
http://www.quittintime.com/
Hey Cal,
That's the filtration system that keeps 6 BIG Koi alive and happy.
You gonna pretty that up too?
Be a shame not to.A Great Place for Information, Comraderie, and a Sucker Punch.
Edited 5/27/2009 11:34 pm ET by RalphWicklund
Most excellent work!Chuck S.live, work, build, ...better with wood
Very nice. I admire your concept for building that monster and the execution too. I hope the Koi appreciate the slendiferousness you've provided for them.
BTW: The filter could be moved to a better location above ground and hidden easily inside something less conspicuous.
I used to install swimming pools so I'm familiar with the plumbing requirements. That filter could be placed at almost any distance from the Koi pond, without compromising its effectiveness.
Edited 5/28/2009 11:08 am by Hudson Valley Carpenter
That is very cool - thanks for sharing the pics!
"...craftsmanship is first & foremost an expression of the human spirit." - P. Korn
bakersfieldremodel.com
