Break Up Granite
FR | Posted in Construction Techniques on February 28, 2007 03:25am
Everyone,
As part of a kitchen remodel,  I need to remove an old granite countertop (approximately 7.5 feet by 3.5 feet.)   It’s not being re-used, no one wants it, and its way too heavy for two people to move so we’re OK with breaking it up.  What the best way to break up a granite slab that will create the least amount of dust? (Hammer, circular saw-diamond blade?)   The adjoining rooms have already been remodeled and the kitchen is still partially functioning so, if this will definitely kick up a lot of dust/debris, I’ll put up the zipwalls.
Thanks.
FR
  1. brownbagg | Feb 28, 2007 03:35am | #1
    I had a slate pool table, I hit with a five pound sledge and it broke into thousand pieces. maybe you can get lucky
  2. frenchy | Feb 28, 2007 03:57am | #2
    FR
     drill it with a series of holes from a hammer drill.. a few minutes and you'll have a break here line..  one swift blow with a sledge hammer should have it in two pieces with no dust.. if that's too heavy drill a big X and break it into four pieces..
  3. andybuildz | Feb 28, 2007 04:08am | #3
    "As I was walkin' - I saw a sign there
    And that sign said - no tress passin'
    But on the other side .... it didn't say nothin!
    Now that side was made for you and me!" Woody Guthrie 1956
    1. plantlust | Feb 28, 2007 04:23am | #4
      (eyes squinting suspiciously) You have a big sign on you that says "I AM THE INSTIGATOR", don't you?Can I just rip out my nose & replace it with a temporary model until this cold is gone?
    JeffBuck | Feb 28, 2007 04:52am | #5
    tap it with a hammer.
    if U just need it chipped ... call an appliance delivery guy to come stand near it ...
    or have the electrician walk thru wearing his tool belt.
    plumber could just eat lunch in the same room ... that works too!
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
      EricPaulson | Feb 28, 2007 06:19am | #6
      ur sharp Jeff, and oh, so right![email protected]
      WHICH content will be free, of course; WHICH content will require registration; but WHICH content will be available only to members of FineHomebuilding.com.???
        JeffBuck | Feb 28, 2007 07:34am | #7
        yet another reason why the tool belt comes off when I do cab installs ...
        and all the tools stay on the floor ... where they can't fall from!
        Jeff    Buck Construction
             Pittsburgh Pa
          PeteDraganic | Mar 01, 2007 03:47am | #14
          I always tell the help when dealing with stuff we don't want to have fall..... "nothing falls off the floor"
          When you're this good, EVERYONE wants a crack at you!
          http://www.petedraganic.com/
    2. Piffin | Feb 28, 2007 03:45pm | #9
      Those only work when you DON"T want it broken!
      HeeHee
      1. FR | Feb 28, 2007 04:52pm | #10
        Everyone,
        Thanks for the advice.   I'll skip the saw and use the hammer and/or drill.
        FR
  5. Jerry18 | Feb 28, 2007 10:13am | #8
    Use a hammer - no dust. Any other spinning type tool will create dust and be more work. If you can pry up one end, even just to put some tension on it and then strike it a few feet away, it will break where you hit it. If you can't pry on it, just keep hitting along a line where you want it to break. It may spall where the hammer hits so wear safety glasses. You could try a couple of layers of duct tape where you will be hitting to keep chips from flying, but you won't have to worry about dust. Unless it's glued down unusually well, it will break up pretty easily.
    Jerry
  6. JonE | Feb 28, 2007 07:40pm | #11
    I'll send you my kids, they can break anything.
    1. brownbagg | Feb 28, 2007 08:59pm | #12
      call god.I keep three sledge in the tool box. big, 10 lb
      bigger. 15 lband ol, my god!!!!!! 25 lb.
  7. User avater
    SamT | Feb 28, 2007 11:21pm | #13
    I want it.
    Are you near mid Missouri?
    SamT
    Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either. [Einstein] Tks, BossHogg.
  8. User avater
    PeteDraganic | Mar 01, 2007 03:47am | #15
    If you are close by, I'll come and get it.
    Where do you live?
    I'm in the Cleveland, Ohio area.
    Edited 2/28/2007 7:48 pm ET by PeteDraganic
    1. FR | Mar 01, 2007 04:36pm | #18
      I'm in Northern New Jersey.   I'm also looking into charitable organizations and my painter may want is also.   But, the project has to move forward so if those options don't pan out,  I'll break out the drill and hammer.
      Thanks Pete.
  9. paulc127 | Mar 01, 2007 06:31am | #16
    I don't know where you are located but I'm sure there is some organization that does home salvage in your area. In my area, (Berkeley, CA) there are groups that will show up an remove the items intact could save a lot of dust and labor
    1. FR | Mar 01, 2007 04:34pm | #17
      Paul,
      My wife is looking into that and my painter may be interested as well.   In about 8 weeks, the appliances and cabinets will be delivered.  In case we can't locate someone, I need to have a plan in place on how to break it up.  I appreciate everyone's input.
      FR
