Broken Trailer Tongue
zbalk | Posted in Photo Gallery on October 15, 2006 03:55am
I bought this trailer early Summer for $50, rebuilt it for around $65 and darn if it didn’t cost $50 to register and license.  Anyhow, I got four months use of it before the tongue broke off right at the frame (right about where you can see the green wire).
My predicament and question are  this.  I don’t want to spend much more money on it since it’s decrepit, homemade with no springs, and actually really small (44″ x 7′), but it served me okay in lieu of anything else.  The I.D. of the remaining tongue portion, that runs the length of the trailer,  is 2″.  I’m considering inserting a length of pipe 3′ or so into that and through bolting it in several places, as a replacement tongue.  I’m not a welder, or I’d try something different.  I suspect that the gauge of replacement pipe is of primary importance.
Does anybody think that this goofy repair would work safely?  Zbalk
    MarkH | Oct 15, 2006 04:07pm | #1
    I think it would work fine, but you should use steel tubing such as race cars etc are made from, not water pipe.
  2. Lansdown | Oct 15, 2006 04:39pm | #2
    On the other hand, the cost of welding is alot cheaper than a law suit and/or hassle should it break while travelling. Once saw something similar happen.
  3. DanH | Oct 15, 2006 04:51pm | #3
    I'd get someone to weld on an appropriate piece of square tubing. Or ditch the whole thing and spend a few hundred for a new trailer from Northern Hydraulic or some such.
    1. formula | Oct 15, 2006 05:05pm | #4
      The replacement tongue needs to extend past the front edge of the trailer bed, preferable back to near the axle. When you load the trailer you create a bending moment on the tongue at the front edge of the trailer bed and the tongue needs the extended length to handle this load.
      1. DanH | Oct 15, 2006 05:51pm | #5
        Right. Ideally a piece of 3" square tubing running from hitch to axle. Probably should NOT be welded at the front of the box, but rather held in place with a bracket, without drilling the tube. This will preserve the max strength at that point.
  4. DanH | Oct 15, 2006 05:52pm | #6
    Another option is to run a truss bar below the tongue.
    1. brownbagg | Oct 15, 2006 06:54pm | #7
      tongue on my trailer is just two angle iron from under trailer at side to center.
  5. ponytl | Oct 15, 2006 08:00pm | #8
    If i was you i'd go spend $100 on a 110v stick welder 90-100 amp or so might cost less at harbor frt...
    i have 2 110v units i all but never use but they both work alot better than i ever thought they would even welded a tongue back on at the race track for a guy once with one... use this as an excuse to buy a tool...
    if you are any kind of breaktimer you can find the scrap steel for free
    i'd find some 3" angle iron and make an A from the hitch  back (start maybe 12" back from the tip of the hitch) and run the feet of the A back to the axle or very close to it...  now you could do this  without a welder and alot of bolts over lapping the angle at the top of the A and bolting thru your existing tongue and maybe beefing up your tongue with another piece of angle... drill a hole and put a carrage bolt anywhere metal crosses and thru your wood deck a few places and i think you'll be ok
    btw... glad we aren't required to lic trailers here... i can count at least 20 on my short list...
    p
    1. rez | Oct 15, 2006 08:04pm | #9
      this coupled with Junkhounds stash of wheelborrows lends credence to the fact that ponyt and junkhound are the undisputed kings of BT packratism.
      be heroes
    2. brownbagg | Oct 15, 2006 08:25pm | #10
      not to change the subject at hand but to add a point.Welder, everybody needs one.Everybody know I do alot of welding.
      I would get a $100 bill and hit the flea market, yard sale newspaper.
      the 220 volt lincoln cracker box. there are millions of them out there
      I could proberly find five for under 100 dollars in one afternoon.I just dont like the 110 models.
      1. ponytl | Oct 15, 2006 09:01pm | #11
        i agree... but i have 2 110v  that really weld well..... 1/8" 6013 rod...  and they both do really well off a 5000kw generator....  better than my miller 220v off the same genset... I don't use my ranger8 enough that it starts when i need it for small stuff... but i do have over 200ft of leads for it... and my own custom welding trailer it's mounted in...If you get a 220  then you need min 50ft of 10-3 that will plug in where your dryer is... a 110 and you can just keep trip'n your breaker... :)
        which BTW i saw 5500kw gensets at biglots yesterday for $450.00  honda knock offs if i didn't have more thn i needed i'd have got an extra... or got a few and waited for the next storm and been one of those bad people that made a profit....
