I am not in the business but have a done a few drywall repairs on my house and a rental ( large patches around windows and a ceiling). I’ve always used paper tape in the past without having bubbles appear along the joints. Recently I was working on another project and every friggin joint had a bubble the length of the joint. What’s going on??
I have heard that fiberglass mesh “tape” won’t do this, but I would prefer to know what the root cause is to avoid problems in the future without “cheating”.
Thanks in advance for any help.
Todd
Hi Todd,
My guess is that the space between the sheets you are taping is to wide. In this case the mud dries in the space and shrinks while the tape on the board dries normally. When dry the tape between the boards pulls away from the mud and leaves the bubble. So either use the fiberglass stuff or tighten up the gaps.
CC
Compound is drying very fast or having the water sucked out of it. pre-wet the tape in a bucket but wipe off the excess water with your fingers first. Use a setting type compound first (durarock, etc.) for easier results.
You can also alleviate a good deal of the problem by setting tape with setting compound. Not the easy sand stuff, but regular Durabond. If you have large voids for whatever reason, you can also use the Durabond to fill those first. Since switching to setting compound for tape, the number of bubbles I get has gone to almost nil.
"The child is grown / The dream is gone / And I have become / Comfortably numb " lyrics by Roger Waters
I have run into this problem in the past, where a patch joined already painted drywall. The area over the painted rock would lift and bubble while the tape over the fresh rock would hold perfectly.
We thought that the moisture coming out of the mud and not being able to get through the paint was causing the problem. Switching to fibertape for the patches cured it anyway.
EARTH FIRST! We'll Log The Other Planets Later.
What were the weather conditions when the tape was applied? Did it rain for a few days or several days of high humidity?
Are you using the joint compound right out of the bucket? If so , thin the mud with some water. Always stir or mix the mud before using. Most ready mix joint compounds have a thixathropic agent added to them to lessen the settling and seperating tendency of pva containing products. Kind of acts like a gel to help suspend the solids. Mixing or stirring releases all the components from the suspension so they work the way they are suppose too.
Dave
Shoulda used duct tape.
Quittin' Time
And the varity of colors.. Perpetual rainbows.
and waterproof
LOL, my roof patch is still holding.
