-Buckled kitchen hardwood
user-108703 | Posted in General Discussion on March 10, 2009 04:28am
Leaks at the kitchen sink caused a nearly brand new hardwood floor to buckle. Hardwood is perpendicular to the cabinets. I need to replace the middle of the floor without removing the cabinets and the huge countertop. What tool will fit under the 4″ cutout of the cabinets so that I can cut the bad floor out. Angle grinder seems a little rude and hard to handle. Franz
  1. webby | Mar 10, 2009 04:39am | #1
    A toe kick saw might be what you could use.
    Check at rental places has a small blade that sits on a shaft out from the motor and fits in the toe kick space.
    Sorrry don't have a picture.
    Webby
    1. user-108703 | Mar 10, 2009 05:07am | #2
      Thanks, toe kick saw a tool I never heard of. Franz
  2. Waterbear | Mar 10, 2009 06:45am | #3
    Fein Multimaster or cheaper equivalent
    1. ugh | Mar 10, 2009 06:48am | #4
      dido to the fien multimaster....
  3. KFC | Mar 10, 2009 07:42am | #5
    You could use a rotary tool, like a dremel, with a toothed attachment, if you have one, or know a hobbyist who has one.
    Or a MM, like they said.
    k
  4. billybatts | Mar 10, 2009 08:33am | #6
    bosch makes a cheap undercut saw
