Can you guys recommend a budget laser that a DIYr can use to do Hardi lap siding? If I don’t really need a laser to do my Hardi can you guys tell me the other ways to make sure I get it nice and straight.
Thanks as always.
Thanks as always.
Listeners write in about ambitious projects and sinking patios before asking questions about old house specialists, attic headroom, and home shops.
Water level. Dirt cheap. Dead nuts accurate.
I've got one of those. I guess sometimes the low tech methods are just as good as the high tech ones.
>>>Dead nuts accurate.Thanks for the reminder... I'm half way through a job and am about to start a side that needs to be aligned with others.... I forgot about the elegant simplicity of my trusty old water level.Scott.
Does the water make the laser brighter? ;-)
"Does the water make the laser brighter? ;-)"No, it's a coolant to keep the laser from burning a hole in the siding...
Thanks Guys. I killed two birds with one stone.
Wait, does your laser shoot stones too?!
maybe that's how he marks the elevations
Yup,big ones.
I got one at harbor freight that cost $7 and its pretty good for like tile layout
water level....
WOW!!! What a Ride!
Thanks.
Stanley has a self leveling laser line generator. It does a level line and a plumb line. I wanted a PLS 2 but couldn't justify the expense.
I was at home depot and saw the stanley unit for around a hundred dollar and figured I would try it and return it if it was a disappointment.
It was so handy I never returned it. I use it all the time. If you can justify the money I am sure a pls2 is better but the stanley is great for the price.
Karl
http://www.amazon.com/Stanley-77-153-FatMax-Cross-Laser/dp/B0007SXI54
Thanks Karl.
water level for the first course- story pole and chalk line for the rest
Thanks Shep.
What Shep said. After you get your first course leveled, you can just mark the Tyvek for all your subsequent courses like story poles. If your runs are more than 12', mark both ends and middle as needed. (Of course, you mark for the *tops* of each subsequent course -- but you knew that.) Snap a chalk line every couple of feet if you want just to make sure everything's working out, but I don't bother.
This method also makes it easy to see if you need to adjust anything so the spacing works out without crazy cuts around windows, etc.
Mike Hennessy
Pittsburgh, PA
Everything fits, until you put glue on it.
I install hardi like I install wood siding. I make a story pole and set it on the foer corners of the foundation. Make the mark on the tyvek and then snap red chalk lines. Firts I snap the bottom course and level.
that tells me I an level, go up from there. By using the snapped chaulk lines everything is level, put the level away and go like the dickens>G<
+1 on H2O level or laser for first course, then story pole for the rest. Story pole will eliminate any possible error (as long as the story pole is correct!), and as said you can check for weird cuts at windows, doors, etc..
you do not, nor should not use a level to hang siding, be it hardi or wood or otherwise.
Story pole or gauge blocks are a good idea though.
I refuse to accept that there are limitations to what we can accomplish. Pete Draganic
Take life as a test and shoot for a better score each day. Matt Garcia
Pete are you talking about the laser or water or both?
both, all etc. Why would you want to use a level to hang siding on a house? No, I am not being funny. Also, have you ever hung siding?
I have never hung siding Pete. How do you do it?
well, I don't use a level... lol.Problem is that if the wall is out of level and the siding is level then it will look crooked. You want to run it with the wall.There may be additional variables in the shape of the wall that also require a few tricks to make look correct.-->-->-->Â
Â
Edited 5/6/2009 7:48 pm ET by PeteDraganic
Want it nice and straight? Measure parallel to your top plate.
You did straighten that for up and down, didn't you?
I didn't think about that one Jim.
'S all good. As a novice carpenter myself, let me recommend 'Measuring, Marking and Layout' by John Carroll. Available from the Taunton press.
Thanks Biff. I have that book, I'll go dig it up right now.
Just flipped through this article again this morning while making coffee. How to use a story pole for siding, from Sept 2008 #197http://www.taunton.com/finehomebuilding/how-to/keep-siding-straight-with-a-story-pole.aspx'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
