Bug screen under composite decking material
strawmyers | Posted in General Discussion on August 31, 2015 12:46pm
I am building an attached screened-in deck onto the back of my house.  I live right on the edge of 30 acres of woods; so the bugs this time of year make it hard to enjoy being outside.  Here is the progress so far:
I’m using Fiberon brand composite decking material (don’t remember the product name; but it’s their style that is wrapped on 4 sides).  I’d like to put screen down on the joists before adding the deck boards to keep bugs/spiders from getting in that way.  Any issues with doing this?  The product requires a certain amount of airflow (cannot be placed directly on the ground), that’s the only thing I can see being an issue.  It’s still bug screen, though, not plastic sheeting that will block all air movement.  Thanks in advance for your thoughts.
  1. DanH | Aug 31, 2015 08:24pm | #1
    The "issue" is that, over
    The "issue" is that, over time, "cr*p" (technical term) will sift down through the cracks and build up on the screen.
    If the deck were high enough I'd recommend screening under the deck with removable panels, but there isn't enough ground clearance for that, judging from the picture.
    1. gfretwell | Aug 31, 2015 08:29pm | #2
      Just put the screen in loose. Mine is about 25 years old and there is plenty of crap down there but it isn't hurting anything.
      deadnuts | Aug 31, 2015 08:32pm | #3
      no issue with air flow
      YOu can vacuum the "cr*p" out of it.
      I'd run the screen as you are planning. We run it all the time w/o issue.
  2. oops | Aug 31, 2015 09:27pm | #4
    deck screening
    Install a screened lattace skirt around the perimeter of the deck.  Would improve the look also.
    1. strawmyers | Sep 02, 2015 08:10am | #5
      I do intend to have a lattice skirt to keep the bigger critters out; but with the piers/etc there, even if I put screen on the back side of the lattice it's going to be difficult to seal the perimeters to the same level of bug-proofness that I can achieve with the above method.  I see the above point about stuff getting in the gaps.  Since it will all be screened in, though, and entry/exit will be from the house 99% of the time, I don't expect much in the way of random leaves and stuff getting in there.  I can hit it with the shop vac as needed.
