Build a deck door
Lerockit | Posted in Construction Techniques on July 26, 2020 06:19pm
Hi everyone,
I am a bit confused on how to build our deck door.  I saw alot of ideas online, and still not sure.
Do you have any pictures or videos to show me? See our deck picture in attachment.
    unclemike42 | Jul 27, 2020 07:13am | #1
    It would be nice if you make the gate mimic the design of the rest of your deck. (the black round balusters)
    You will need to include a diagonal cross member to avoid eventual gate sag. (Z shape)
    This one is at least 25 years old.
  2. firedudec56 | Jul 27, 2020 11:59am | #2
    make the gate frame w/ 2x stock, drill the top & bottom in the center for the black balusters, and make the z cross member from decking (basically either 3/4 or 5/4 stock) fastened to the outer edge of the 2x stock w/some blocking to fill in between the balusters to provide support/alignment - done!
    if there's any top & bottom railing stock already pre-drilled, you just need to get some stock for the sides and the z bar - center a 2x top plate on the railing stock and it'll match up w/the 4x4 stock posts
    bit of work but should look like it belongs
    good luck
    1. Lerockit | Jul 27, 2020 12:11pm | #3
      Hi,
      The only thing with a crossover, it is not the best look. I just saw online a metal crossover, I think that will do the job.
      Thanks, that was a great help.
  3. firedudec56 | Jul 27, 2020 02:16pm | #4
    looking at your picture again, use 2x stock to copy the railing design but rip the railing stock down so you match the railing edge height in the gate but have a 2x frame around the railing stock, that will sort of let people know that's the gate with the wider top, then you could use a cable w/a turn buckle to transfer the load and prevent the gate from sagging - would at least be a less "intrusive" look - paint the cable black and it blends with the balusters
    basically make a 2x box and use the railing stock inside - similar to what used to be done for porch railing on the old Victorians and such. looking at "uncle Mike's", you could use 5/4 decking for the box like he did - less "massive", lighter look to the gate and a lighter gate, easier on the hinges and framing
    just some thoughts
    nice looking deck, always good to have some fall protection at the stairs -
    good luck
Picture-Perfect Pergola
