Building a block wall on slab
AndyM457 | Posted in General Discussion on March 24, 2022 01:29pm
In my basement I am wanting to put a storm shelter.  It is a 4″ concrete slab, and under that is plastic underlayment and about 4 to 6″ of stone.   The ground underneath is pretty much solid sandstone.  I was wondering if I could put a concrete block wall on top of the slab,  if I would need to drill holes and drive in rebar, or if I would need to cut the concrete, dig out and pour other footers?  The edges of the slab rest on about 3 to 4″ of the footer.  I am only wanting a 7′ wall with a metal or concrete roof on it.   Any help would be appreciated.   I have not seen any evidence of settling problems in the basement.
  1. greg_e | Mar 24, 2022 03:58pm | #1
    I'm assuming a tornado shelter? A 4" Slab is just not enough to anchor anything substantial to. I would cut the slab and pour a footing (depending on the size of your shelter a thickened pad for the shelter might be the easiest way). I would build the walls like a concrete retaining wall. Also I would pour concrete instead of block. The block needs to be grouted anyway, so just build forms and pour concrete. I started construction building forms so I am likely biased in that regard. Good luck.
    1. bing0328 | Mar 24, 2022 05:31pm | #2
      In general I agree with Greg, but given what your trying to accomplish, talk to a structural engineer. If I was sitting in the shelter, I would want to know I did everything I could to protect my loved ones sitting next to me, while the world is trying to destroy me.
  • Townhouse Transformation
