Building a mantel??
jr40 | Posted in Construction Techniques on November 12, 2009 04:31am
I have a large California drift stone fireplace with lots of BIG stones protruding and my wife has always been after me to build a mantel.  My problem is that I have no idea how to build it with all the protrusions.  I am a little bit leary about using a hammer drill with several thousand lbs of stone above my head.  I am thinking about strategically placing steel rebar (?) into several spots, attach a 2×6 and box it in with some 1x lumber.  BUT, how in the heck do I scribe the 1x’s around the protruding stones?????   Is this even possible,safe?  Help.  I have had great luck with help on many problem areas and this one is tough.
  1. DanH | Nov 12, 2009 04:50am | #1
    "Protruding" how much?
    A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
  2. jackplane | Nov 12, 2009 05:02am | #2
    Level the top first with mortar or tinted mortar, then attach your mantel. Scribe and cut the back edge touching stone.
    Expert since 10 am.
    1. Piffin | Nov 12, 2009 01:53pm | #5
      "Level the top first with mortar or tinted mortar"What does the top of the chimney have to do with a mantle? You don't want it level anyways, you want water to run off.
      1. jackplane | Nov 12, 2009 04:21pm | #6
        I envisioned a more or less squared off fireplace, to which he was adding a mantel. I see he means vertical stone, floor to ceiling or similar.Expert since 10 am.
      2. Clewless1 | Nov 12, 2009 04:34pm | #8
        I think he meant to level the stone where he wants to put the mantel to make an even match. Colored grout will help make it disappear.
        1. Piffin | Nov 13, 2009 02:03pm | #11
          bring the stone surface out to a flat plane then....The misuse of the word 'level' is what threw me off from what he was trying to say.
          I expect that from my wife, LOL - "you knew what I meant"
          1. DanH | Nov 13, 2009 03:21pm | #12
            But isn't that what Holmes (or whoever it is) says?
          2. Piffin | Nov 13, 2009 03:27pm | #13
            yeah, in ref to plumb, but this is describing flat, not plumb nor level.
          3. DanH | Nov 13, 2009 03:41pm | #14
            I suppose. How would one describe a ditzy blond? Nor flat, not plumb, or off level?
          4. Piffin | Nov 13, 2009 03:50pm | #15
            Is she flat chested or does she have a couple of distractions to keep you from noticing whether she is ditzy or not?
    PeterJ | Nov 12, 2009 05:43am | #3
    How about standing the mantel off the stone surface? Here's some pics of ours, pipes inserted during construction I'm sure, but perhaps you could do something similar by drilling. Don't think I'd be scared of roto-hammering unless there's reason to think wall integrity in marginal. It's not like you're jack hammering the thing.
    One pic is looking down the length of the mantel and shows the gap (not too clearly, but maybe you get the idea) between mantel and stone. Mantel is supported on 4 pipes, looks to be 3/4 emt.
    I can get some better pics of details in daylight if you're interested.
    1. Jed42 | Nov 12, 2009 07:39am | #4
      ...aaahhhhhh if only those stone fireplaces WOULD come down that easy when you WANT them to!No Coffee No Workee!
    2. Clewless1 | Nov 12, 2009 04:37pm | #9
      That's kind of what I was thinking. Usually probably no need to have it match exactly and from across the room or at the sofa, you'd probably not realize it. I don't 'get' your second pic, though. Have no idea what it is showing.
      How'd you get the lighting? You have a hollow mantel w/ lights and glass top/bottom?
        PeterJ | Nov 12, 2009 05:57pm | #10
        Yeah, I knew it was a reach, no good way to photograph with flash. It's hollow with flourescents strips inside and "windows" top and bottom, supported on stubs of EMT in the masonry.
        Really what I was getting at was that a "floating" mantel might be a possibility rather than trying to fit an irregular surface.
        1. Clewless1 | Nov 13, 2009 04:45pm | #16
          I know ... and I agree ... there may be no reason for a 'tight fit'. Why beat yourself up trying for the tight fit when a mantel could float? Your mantel surely makes a statement! What people normally put on the mantel really doesn't require the tight fit. A tight fit is normally done ... but usually only because it is integrated into the original design where e.g. rock is brought down to the mantel and then starts again below.
          Gotta think outside the box sometimes, yaknow? That's what I like about BT ... there is always a 'sideways' thinker who nudges you off that think path w/ blinders. Ain't the internet great?!!
            zachariah | Nov 13, 2009 05:59pm | #17
            Here is a mantle I did for my FIL, I drilled into the stone and the cedar log, inserted all thread into stone held in place with redhead epoxy. Very strong and not bad looking if I do say so myself.
            Edited 11/13/2009 10:01 am ET by zachariah
          2. AitchKay | Nov 13, 2009 10:13pm | #18
            Aw, you "float it" guys are no fun!Tweak out, and earn yourself some bragging rights with your dinner guests!Check out this scribe job:AitchKay
            zachariah | Nov 13, 2009 10:54pm | #19
            Wow!! Please elaborate, method, time spent, etc.
          4. AitchKay | Nov 14, 2009 05:29am | #24
            As soon as I can figure out how to embed pics in the text, as you do, I'll start a separate post on that project.Any hints as to posting from a Mac? I've played around with Picasa a bit, but still can't do it.One regret that I have about my mantel is that I didn't keep as much of the "log" as you did: although I went for a drawknife-assisted chamfer throughout, that still wasn't enough.Another time, I'd make the bottom front edge way more waney. I like the way that, with the cedar you used, you have that bold sapwood edge curling around the endgrain, accentuating the lines of the log itself.Lots of ways to skin them old cats!AitchKay
            zachariah | Nov 14, 2009 03:58pm | #25
            I'm not sure you can post with picasa, I know you can't with firefox on windows, I have to use internet explorer but I found out how by doing an advance search on here, if anybody knows how I'm sure they posted directions. That is one of the many things I love about this site!
          6. DanH | Nov 14, 2009 04:28pm | #26
            It's a little more work to embed pictures with Firefox, but it's doable.
          7. User avater
            zachariah | Nov 14, 2009 04:34pm | #27
            I just started using it so I don't know the tricks yet, can you explain?
          8. DanH | Nov 14, 2009 05:00pm | #28
            Well, we'll skip over making the picture accessible and assume it's on Flickr or some such. Enter your text like this, then a couple of<br/><br/>(These are known as "breaks" -- they create space). Then<img src="http://farm4.static.flickr.com/3091/3188167160_368e796902.jpg"/>Then, if you want more text afterwards, more breaks first.The important thing is to look down below the text window and check the "Check here if HTML tags are in the message" box before posting. And it's always wise to do a "preview" first, before hitting "post".The most common mistake made when posting photos (besides posting oversized pictures that everyone hates) is to post something in your private photo directory, that other people can't access. This results in the infamous red X (or sometimes nothing at all).
          9. User avater
            zachariah | Nov 14, 2009 05:25pm | #29
            wow, thanks I think I'll stick with IE for now.
          10. AitchKay | Nov 14, 2009 06:34pm | #30
            Hey, Dan,Thanks, but I followed your instructions to a "T" several times, and it won't work for me.I don't know if it's my Mac, the Picasa site, or what.And sorry about the hijack, jr40!AitchKay
          11. DanH | Nov 14, 2009 09:00pm | #32
            Should work the same for any browser. What didn't work?If the <> characters showed up you forgot to press the "Contains HTML" button. If the image doesn't show up it usually means the image isn't accessible over the net or you somehow messed up the syntax.
          12. AitchKay | Nov 14, 2009 09:26pm | #34
            I copied and pasted your instructions to a blank doc so I could have it side-by-side with my post to double-check.Made the Picasa Gallery public.Checked the HTML box.Copied and pasted the link.I even copied and pasted your text once to see if I'd screwed up any keystrokes.Clicked Preview.Just a blank space in the text.AitchKay
          13. DanH | Nov 14, 2009 09:35pm | #35
            Here's what I get if I just literally copy my previous post and click "contains HTML":
          14. DanH | Nov 14, 2009 09:38pm | #36
            And this is the same, only from Opera:
          15. AitchKay | Nov 14, 2009 09:46pm | #37
            Still a mystery.I did an AS and found the "I'm out of pixels" thread. Fat Roman gave me some similar but different advice.Still nada.AitchKay
          16. DanH | Nov 14, 2009 09:50pm | #38
            Yeah, I've never figured out why some people can do this and others seem to struggle. I'm guessing there's some niggling detail that being missed, perhaps something in your profile like the basic/advanced setting.
          17. AitchKay | Nov 14, 2009 10:14pm | #39
            Maybe a character flaw?Genes?Bad diet?I DO suffer from shortness of pants...AitchKay
          18. DanH | Nov 14, 2009 10:21pm | #40
            Like I said, maybe it's your profile. Strip down and check yourself out in a full-length mirror.
          19. DonCanDo | Nov 14, 2009 10:45pm | #41
            Yeah, but no pictures of that, please.
          20. DanH | Nov 14, 2009 11:15pm | #42
            With his luck, that's the one that WOULD show up OK if he posted it.
          21. AitchKay | Nov 15, 2009 01:03am | #43
            I've finally figured out how to embed (thanks, Fat Roman), but now I'm having a lot of trouble with glare from the flash in the mirror.And I'm getting a bit chilly. But don't worry, I'll get a good profile pic posted sooner or later!AitchKay
          22. DanH | Nov 15, 2009 01:08am | #44
            The image is a little fuzzy in spots:
          23. AitchKay | Nov 15, 2009 01:16am | #45
            But at least there's no glare from the flash.AitchKay
          24. Henley | Nov 14, 2009 06:39pm | #31
            Hold on a minute! Is that a Rivendale?Nice bike regardless. Fixie or singlespeed?
          25. DanH | Nov 14, 2009 09:00pm | #33
            Dunno -- I just grabbed the pic off public photos on Flickr.
          26. Shoemaker1 | Nov 14, 2009 02:08am | #20
            CNC termites?
          27. mikeroop | Nov 14, 2009 02:15am | #21
            looks nice and time consuming!
          28. AitchKay | Nov 14, 2009 02:39am | #22
            Beaver on a leash.AitchKay
  4. AitchKay | Nov 12, 2009 04:34pm | #7
    I successfully scribed in (no gap bigger than 1/4") a solid oak 8" x 14" x 10' mantle once.
    I started by making a hollow pine mock-up. When I liked the fit, I took it apart, clamped each piece of pine to the beam, and went over it with a top-bearing bit. That was the easy part.
    Hollowing out the beam and back-cutting the scribe was where I spent most of my labor. Chainsaw blade on a mini grinder -- YOW!
    It was a fun job, though, and I'd do it again.
    AitchKay
    Dinosaur | Nov 14, 2009 04:52am | #23
    Scribe or don't scribe the back edge of the mantle; that's an æsthetic choice that's up to you and SWMBO. Scribing isn't that big a deal once you figure out how to hold the piece to be scribed firmly in place while you do it.
    Removing the material can be done with any number of tools, depending on the thickness of the piece. A chainsaw wheel on a grinder is a good choice to remove a lot of material quickly, but practise on scrap beforehand if you've never used one before. And don't run one without the guard in place. (Don't ask me how I know that, please....)
    To mount the mantle to the stone wall, get out the Bulldog and bore appropriate sized holes (for half-inch anchors, usually 5/8") into the biggest, most solid stones you can find, on approximately 16" spacing. Stay away from the edges of the stones; don't drill into the mortar/grout between them.
    Drill the mantle beam to match (drill the holes slightly oversize to allow you some wiggle room), and counter bore the holes for washers and nuts.
    Insert Hilti anchors in the stone, slip the mantle beam over them, and run the nuts down hand tight. Now level the beam and brace it in place, then drive the nuts down tight in rotation. Do not use an impactor; use a short-handled socket wrench so you can feel how tight you're getting. Expanding Hilti anchors exert a lot of sideways pressure, and you do not want to split any stones at this point.
    Cover the nuts with blind plugs, button caps, architectural moulding, or veneer.
    Dinosaur
    foolish men call Justice....
  6. jr40 | Nov 16, 2009 11:07pm | #46
    Thanks for the help.  The stones are large.  Took two of us (several took 3 of us) to lift and place.  The profiles are very different, some faces are 4-6" different in depth.  Sorry, I don't know what the Bulldog is.  Haven't used Kilti anchors but will try.  I really want to scribe as close as possible.  Have used the chains saw blade for roughing out 3d figures.  I just have to figure out how to hold the mantel board at the right height and level to do the scribe.  I am going to give it a try and hope the 300 lber's don't give way.
      Dinosaur | Nov 17, 2009 04:37am | #58
      A Bosch Bulldog is a rotary hammer drill. They come in several sizes, from 'happy homeowner' size all the way up to demolition models capable of busting up the floor slab in your basement. You will only need one big enough to put a <1" hole in stone.
      Hilti anchors. Hilti is a brand name; generically they are known as 'wedge' or 'expansion' anchors. They expand and lock in place when you crank down on the nut that pulls the workpiece towards the wall.
      To scribe something too big to hold in place, you can 'spile' it instead. This is a boatbuilding technique. Simply put, you build a light skeleton spile board the same overall dimensions as the workpiece, and wedge, jam, shim, pinch, or whatever you gotta do to hold it in place exactly as if it were the workpiece itself. Then you scribe that...and transfer the scribed marks to the actual workpiece.
      In your case, I would probably not bother. I'd just build a couple of sawhorses to fit the situation and hoist the actual workpiece up onto those and shim it into place against the stone then scribe it directly. Spiling I usually reserve for things that go around three or four corners in two different planes simultaneously.
      Dinosaur
  7. jr40 | Nov 16, 2009 11:21pm | #47
    Your idea is a good starting point.  BUT, some stone faces extend 4-6" beyond adjacent faces.  That would leave lots of space between mantel and some stones.  Wife wants about a 8" deep mantel.  about 6 -7' long and 4" thick.  I think a box might me my best bet.  Thanks for the idea.
    JR
    1. DanH | Nov 17, 2009 12:30am | #51
      I think if you were a bit creative you could make yourself a fitting jig of some sort. Eg, get a couple of 1x pieces as long as the mantel plus maybe 8", run bolts and thumb nuts between the two pieces every few inches, then stick shorter pieces of 1x in between the two long pieces at right angles. Hold the jig in place, slide the short pieces in/out to conform to the surface, then tighten the thumb nuts.Dunno if it would help, but it's a thought.
        PeterJ | Nov 17, 2009 01:34am | #53
        I think you're onto something there, a mega version of this kind of thing;
        http://www.mannyswoodworkersplace.com/contourgauges.html
        You could take a reading where  the top of mantle goes , transfer to mantle and then do bottom. Bet this would get the big work done without even setting the mantle in place.
        If the thing is really heavy, you could build a little staging for it, maybe even a slide up ramp if working by yourself.
        1. DanH | Nov 17, 2009 01:58am | #54
          Yeah, that's the basic idea. But only have maybe eight sliders (depends on how irregular the surface is) to keep weight under control. You could probably make one light enough that the wife or kid could hold it up while you set the sliders.
        2. AitchKay | Nov 17, 2009 02:16am | #55
          Stay tuned. I only held my 400# mantle up to test fit it once... and I never took it down.AitchKay.
  8. Piffin | Nov 16, 2009 11:22pm | #48
    Looks more like spots in the fuzzy to me
  9. jr40 | Nov 16, 2009 11:25pm | #49
    Thanks bud.  I like the idea.  Here goes nothing.  My gaps however are going to be up to 6" in several places.  Holding the board to be scribed is my next feat.  Looking at some bracing ideas.  Or maybe skyhooks.
    1. AitchKay | Nov 17, 2009 01:25am | #52
      I'm going to post a thread on mine as soon as I get the time, I hope in the next few days -- I finally got my pics scanned, and have figured out how to embed them.The thing that made me know I could do it is that masonry has large gaps all over (called mortar lines), so a 1/4" gap would look really tight -- as opposed to a wood-wood scribe, where you better have it darn close to perfect.I was right -- 1/4" wood-stone gaps look like a million bucks!AitchKay
  10. jr40 | Nov 16, 2009 11:31pm | #50
    That is a great look.  Thanks for the pics.  My stones are not as flat faced as those.  And I think I will quit beating myself up with tight fit ideas.
  11. User avater
    FatRoman | Nov 17, 2009 03:11am | #56
    I can't believe I just burned time looking for this info. LOL
    It's a Traffic bike. Kind of cool, isn't it.
    Here's the Flickr set for the singlespeed http://www.flickr.com/photos/trafficbikes/sets/72157612636597343/
    More sets of photos http://www.flickr.com/photos/trafficbikes/sets/
    And their site http://trafficbikes.com/
    'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
    1. Henley | Nov 17, 2009 03:50am | #57
      Yeah, that is a very nice bike. I haven't been tempted by the single speed bug myself but
      it makes for a clean looking ride. Riser bars and a brooks saddle nice combo.
  12. AitchKay | Nov 18, 2009 06:50am | #59
    Hey, JR,
    You inspired me to finally scan my pics & Polaroids, and figure out how to embed them!
    I've done enough hijacking of your post, so I'm starting my own thread,
    "Solid-Timber Mantle Scribed to Stone," 126689.1
    I had a lot of fun making that mantle. It was one of my all-time favorite projects.
    AitchKay
