Building a new non-loadbearing wall…
bk73 | Posted in Construction Techniques on February 25, 2008 06:20am
on the second floor of our house. I am redoing a bedroom and moving a closet from one side of the room to the other. It is a non-loading wall, parallel with the floor and ceiling joists. There is existing wood flooring where I want to place the wall.
Do I have to remove a strip of flooring so I can place the wall on the subfloor or can I nail the wall directly to the wood floor?
I don’t think the wall is going to rest on one of the floor joists b/c they run parallel with the proposed wall. Is it necessary that the wall sit on more than just the subfloor? Do I have to add blocking between the floor joists, which I really don’t want to do b/c I would have to open up the family room ceiling.
Thanks.
Brad
  1. Waters | Feb 25, 2008 06:47pm | #1
    Do I have to remove a strip of flooring so I can place the wall on the subfloor or can I nail the wall directly to the wood floor? No, just screw it to the floor--pre drill or use 3"deck screws that 'self tap' so you don't totally split/crack the hardwood floor.
    I don't think the wall is going to rest on one of the floor joists b/c they run parallel with the proposed wall. Is it necessary that the wall sit on more than just the subfloor? Do I have to add blocking between the floor joists, which I really don't want to do b/c I would have to open up the family room ceiling.  It's only a closet--and there was nothing structural at that location before so there's really no need to beef up anything in the floor or provide nailer...
    The way I look at it, somewhere down the road, someone could possibly gut the room again and change things.  This way, all they have to do is 'unscrew' the wall, refinish the floor and go.
    Thanks.
    Brad
    "Research is what I'm doing when I don't know what I'm doing..."
    1. FastEddie | Feb 25, 2008 11:08pm | #2
      I think you meant AND not OR. "Put your creed in your deed."   Emerson
      1. andyfew322 | Feb 26, 2008 02:07am | #3
        no, you only have to drill a hole, and the magic screw fairy comes in while you sleep and puts a piffin screw in   ;)
        screw fairy...... think about it. wow.
        Ductape can fix EVERYTHING!!!
        Edited 2/25/2008 6:08 pm ET by andyfew322
        1. frammer52 | Feb 26, 2008 02:13am | #4
          blank,blank kid
      2. Waters | Feb 26, 2008 04:27am | #5
        What?  You haven't been visited by the screw fairy yet?
        PDB.."Research is what I'm doing when I don't know what I'm doing..."
        1. brucet9 | Feb 26, 2008 08:06am | #6
          "What? You haven't been visited by the screw fairy yet?"Presumably one can make an appointment through http://www.McFeelys.com?
          BruceT
          xxPaulCPxx | Feb 26, 2008 08:17am | #7
          Did somebody call me?
          What, why is everyone laughing?
          Also a CRX fanatic!
          If your hair looks funny, it's because God likes to scratch his nuts.  You nut, you.
