building a sauna
hammer | Posted in General Discussion on December 31, 2004 12:19pm
Does anyone have experience building saunas?
My son and I want to make an outdoor sauna (in Minnesota). I’m looking at about 250 cu ft. I got about 300 sq.ft of 1X6 TG cedar from a demo and will use that inside and out. wondering about insulation and a choose of heat source.  The electric dry/wet units are expensive so I was considering a wood burning unit (stocked and vented from outside.
Any suggestions or ideas?
  1. rez | Dec 31, 2004 12:42am | #1
    http://forums.taunton.com/tp-breaktime/messages?msg=48351.1
    http://forums.taunton.com/tp-breaktime/messages?msg=48426.2
    http://forums.taunton.com/tp-breaktime/messages?msg=43708.1
    http://forums.taunton.com/tp-breaktime/messages?msg=37304.1
    http://forums.taunton.com/tp-breaktime/messages?msg=14329.2
    http://forums.taunton.com/tp-breaktime/messages?msg=517.1
    1. hammer | Dec 31, 2004 02:31am | #2
      Wow.. A lot to read. Thanks
      1. rez | Dec 31, 2004 03:27am | #3
        Sure. Glad to help. There's still plenty floating around in there.
        If you scroll down in the lower left corner of your screen there is a search function that will take you to previous threads dealing with whatever you type in the search bar.
        If you type in 'sauna' or other keywords of the subject matter you'll get a good supply of data from those old threads.
        Cheers
