Building a Stronger and More Efficient Home: The Larsen Frame House by Hempbud
Hempbud | Posted in Construction Techniques on April 19, 2023 02:30pm
Hello! This is my first post, and I would like to share with you, the frame builders, my options for frames using John Larsen’s technology. My name is Ilya Svetashov, I am a visionary of HEMPBUD UA, Ukrainian company working in the field of ecological and energy efficient prefabricated housing.
Hempbud, a Ukrainian construction company, has recently unveiled their new fast-assembling frame house using the Larsen technology. The house, which was constructed in Kiev, boasts of several advantages over traditional single-frame houses.
One of the key features of this new design is the use of double light frame structures instead of single ones. This provides added strength and durability to the structure, making it more resistant to the elements and wear and tear. The frame structure also allows for more insulation space, resulting in increased energy efficiency and lower heating costs.
The frame’s dimensions are 3×4 cm, which translates to approximately 1.2×1.6 inches. The use of lightweight materials makes the assembly process much simpler than traditional building methods, and the company provides detailed instructions for easy installation.
The company also provides an insulation kit for an 18 square meter interior space using the Hempire Mix insulation from Hempire UA. This insulation material is made from hemp, which is known for its thermal insulation properties and is environmentally friendly. My name is Ilya Svetashov, I am a visionary of HEMPBUD UA, Ukrainian company working in the field of ecological and energy efficient prefabricated housing.
Hempbud’s new frame house design is a significant development in the field of eco-friendly, energy-efficient housing. By utilizing lightweight materials and modern construction techniques, the company has created a product that is not only easy to assemble but also durable and sustainable. This new design is sure to attract attention from homeowners looking for a more affordable and environmentally friendly housing solution.
I would like to hear the opinion of experts! Thank you for your attention to the topic
Old House Air-Sealing Basics
