Building Door Arches
| Posted in General Discussion on January 27, 2001 04:41am
What is the best or should I say quuickest or least expensive method for creating graceful semi-arched doorways that are so popular? The materials to use is not the problem. The layout of the arch and cutting of the arch is the trick. I have four doorways of varying widths. They are in a home with 9 foot ceilings and the R.O. Ht. is 7′-8″,so I have some play. Should I make a template on the floor. Add a router to large home made compass? Use a Rotozip or a jig saw for the arch cut? Do I need to wrap the bottom of the arch with plywood or OSB? The openings will be finished with drywall. No trim as of yet!
Any help would be appreciated,
  1. Dennis_Peters | Jan 27, 2001 04:41am | #1
    What is the best or should I say quuickest or least expensive method for creating graceful semi-arched doorways that are so popular? The materials to use is not the problem. The layout of the arch and cutting of the arch is the trick. I have four doorways of varying widths. They are in a home with 9 foot ceilings and the R.O. Ht. is 7'-8",so I have some play. Should I make a template on the floor. Add a router to large home made compass? Use a Rotozip or a jig saw for the arch cut? Do I need to wrap the bottom of the arch with plywood or OSB? The openings will be finished with drywall. No trim as of yet!
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
