Building Your Own Exterior Wood Door
Hi All.
We are currently building our own house. It is a timber-framed, light straw/clay construction house in Southern Alberta. I have been toying with the idea of trying to build my own wooden, front exterior door, especially after looking at the price, and dullness of factory pieces. The entrance is very well sheltered from sun and moisture but the door is still of course, subject to RH variation, both in the exterior environment and the huge gap between interior and exterior environments here in arid Southern Alberta. I have never built a door before.
Does anyone have any good web tutorial sources or specific advice? Is it worth that time, hassle and risks of it not turning out?
I included a few pictures of the project.
Mark
It depends on the type of door you're looking for. I had a neighbor who made a "slab" door from 2X6 tongue & groove cedar cardecking. He held it together with 2 tapered sliding dovetails on the back which were anchored at one end only. The big crosspieces and wrought-iron nails on the outside were just for decoration. Took him an afternoon to build.
I think that would an amazing project to undertake, the only problem I could forsee would be squareness and flatness, if you could overcome those two obstacles the finished product would be amazing. A large router with a 1/2" upcut spiral and a jig could make you some really nice mortises, would hold the door together no problem. go for it.
Do you know anything about core construction? I have seen some techniques where you glue your panel pieces to a stable core, but then leave expansion and contraction room in a v-joint to absorb wood movement due to RH changes.Mark
What type of door are you looking at making? Picture?
Mark,
I'm starting on the same project within the next couple of weeks.
3-6 by 7-0 with door with possible sidelights for a covered front entry. Have the plans drawn out but am tweaking, especially the sidelights. If no sidelights then the door will likely be a 4-panel with two light. If sidelights the door will likely be a 4, 5, or 6-panel with no lites.
My wife is still scratching her head over what exactly she wants.
Will likely be solid lumber, not veneer over a core. That does depend on the lumber available though, in regards to the grain. Prefer VG over flat sawn, etc.
I'm doing floating tenon construction. Most likely either mahogany or spanish cedar. Went to the yard last week and the pickings were slim, they're getting another 600-700 bdft in this week.
If your table saw is properly tuned then the door fabrication and assembly should be fairly straightforward and turn out well.
Unfortunately I don't know of a website that provides a tutorial, though while I was at the lumberyard they had a New Yankee Workshop show on that showed Norm building an entry door. I saw bits while waiting, his final product looked nice. Here's the URL to that episode: http://www.newyankee.com/getproduct.php?0702
The irony is that I was contemplating bulls eye glass, there's a glassblower a few towns over that makes it.
Hey Mongo.Thanks for the encouragement and advice. I feel a little intimidated by some of the warnings I have read over what considerations need to be included.I have some 80 year old, old growth Douglas Fir in big beams from a grain elevator salvage. I could resaw this and get something close to vertical grain if I was extravagant in how I cut down a beam or two. Any tips on that?Would love to see the plans you are working with.I will check out the link later.Take a look at our project on our farm website wwww.harvesthaven.com and go under "new buildings".Mark
Mark,If you've got a good window/door place in town go there and take a look at some cutaways of door construction. You'll see the cope and stick joints on the rails/stiles, and the large reinforced dowels.I'm with Mongo on using solid lumber over veneer. And hearing that you have some old beam stock made my eyes light up. Definitely use that. VG fir is a great wood for an exterior door, the majority of the old doors in the NW are going to be made out of that nice, old VG fir.When you're milling that beam down for rail and stile parts, here's a couple things:•Avoid knots and any "special" looking grain areas. These may contain hidden stress areas of the wood and will want to warp or twist when you mill through there.•Mill your stock to rough dimensions first and then let it acclimate for a bit to make sure that there are no stressed ares that will move. Then mill it down to final size and double check that everything has stayed nice and straight. That old DF is really nice stuff to work with IMO. I pull out old stairs, studs, and lumber and keep it just to use for building doors, windows, and cabinet parts. In one of the pics below you can see some old DF stair treads and handrails sitting up on one of the shelves. The ones above it are overflowing with beautiful old studs.A few other things to think about:•As you're planning your door remember to think like water. Shaker style is real nice looking but if it's exposed to the elements water will have a nice little shelf to sit on and collect. If you're doing some sort of panels, the coped part will probably have some sort of ogee or bevel which should help move water downward.•Also may want to pre-finish your panels, at least around the edges, so that they are protected all the way down as the wood expands and shrinks. Otherwise as it shrinks, you'll see a nice halo of unfinished wood around the perimeter.•My local door and window shop restricts their individual pieces to about 5" or so max width. That means if you want a 9" bottom rail, you'll want to join 2 or more pieces together. This minimizes the chance of warping, cupping, or checking over time.Here's some pictures from an exterior screen door I built a few months ago. NOt a true exterior door, but some of the same principlesThe bottom rail is 12" high, made out of 3 pieces joined together with loose tenons and copious amounts of waterproof glue (The top is beveled somewhere around 8 degrees or so to shed water). The rails are joined to the styles with a stub mortise and tenon reinforced with loose tenons. Door manufacturers, like Marvin, use big honkin' dowels instead of tenons, but that's easier for them to do, and plenty strong. If you take apart old frame and panel doors, a lot of them have a cope and stuck joint reinforced with mortise and tenons, sometimes through, sometimes not.Here's a pic of the finished product:
http://www.pauljohnsoncarpentry.com/Paul_Johnson/Arched_Doorway.htmlHope any of that helps some. The 2 biggies are just to make sure you've got nice straight lumber that won't twist/warp once you've milled it down, and plan your door so that water is always moving down off of it.Paul
Hi Paul.Thank you for the great reply and the encouragement and for the excellent pictures! I went out to work on the house today thinking, "I've got so much to do out here, I don't have time to build a door. I will just have to buy one, no matter how uncreative and expensive they are." However, thanks to yours and other letters of encouragement, I am dreaming up doors again. Your work looks beautiful. I wish I could spend more time just doing wood working, rather than wearing all the hats I do.I see you do a little timber frame work too. We are hosting a Japanese timber framing seminar next June and July. We are having a temple and tea house apprenticed timber framing friend come over from Japan to help us build our new 4000 square foot organic food store/organic bakery & bistro/alternative health center and will have him offer a couple of workshops while he is here.If you want to see more about the project, go to our farm's website, http://www.harvesthaven.com and look under "new buildings". It is just a few of us doing all this stuff, so everyday is ... interesting to say the least. Thanks again.Mark
When we built, put the cheapest doors on to start with. After we moved in and got all else finished, then went back and replaced the outside doors (5 of them).
It was 20 years till all 5 were replaced <G> Will post some pix later today, all were made out of salvaged materials, none cost more than about $10, hardware included. Probably most of the $$ was glue.
You may be suprised what you can do with salvage and almost no $$.
r
Since you are planning to buy I suggest you make a trip to Black Forest in Calgary. They make some beautiful custom doors and have a carver on staff that will make custom carvings to your liking. An acquaintance is building a timber frame house and they dropped $10k on their door, but it was worth it in my mind. Building your own is big undertaking.
good luck
Nice work. Did you do a thread on this door before? I'd be interested in seeing more on how you handled the arched top.And, are those homemade dominoes?'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
Hola Sr. Roman,I think I posted some pics of it before when Huck asked a couple questions about it, but never did a full blown thread on it. Maybe I'll start a new thread on it so I don't hijack this one too much. I'll look for the pics I have of it and see what I can throw together.Paul
I don't have the ability to resaw logs or beams, but the idea or resawing your own sounds terrific. There will always be a nice story to the door, where the wood came from, etc.
My scanner doesn't scan to my macs, so I can't scan the drawings to file and post.
My advice would be to make something quick and temporary. You seem to have a lot on your hands, and making a nice entry in a one-off mode is quite time consuming.
The production guys buy kiln dried wood and work in a tightly-controlled, mechanized environment; and they rely on volume. You don't have any of that going for you.
I've made a few doors, some were good, some were cr@p. Either way, they take time, especially if you want to do something nice.
Good luck,
Scott.
Doors are not difficult to build, but require a certain level of tooling to be able to produce straight and square components and to cut the joinery required. Floating tenons and router cut mortises make a strong door. Solid panels can easily be set in a dado in the rails and stiles, lites are a bit more complicated because they need to be removable so must be set in rabbets and held in with keeper strips. That can involve mason's mitres or matched and opposing rabbets in rails ends and stile. I've often used twelve inch VG stock for the bottom rails with no issues and this is coastal BC with much greater humidity swings and interior/exterior differentials than you'll see in south AB. I do tend to build with at least one centre stile so panel size is limited to about 12". Just make sure the wood starts dry and be sure it is well finished 6 sides.
You might find it more economic in the long run to just find a supplier of 2" VG stock than to spend the time to resaw beams to VG, and the beams do have greater value as beams than as lumber. VG doug fir is easily available in BC at ~$6 BFM so should be accessible in AB.
If it doesn't turn out you can always try again or buy a replacement. Just make sure your frame is standard sized so purchased doors will fit. If it does work, you'll be some pleased with yourself and have a nice door, a new skill and a few extra bucks in your pocket
>>>VG doug fir is easily available in BC at ~$6 BFMTrue. I've always wondered how 6 bucks a board foot (retail) for materials resulted in $600 to $700 door (unfinished). I know it's a competitive market, so I'm not about to argue with anyone about costing, but I don't understand how the value gets added.Seems to me that the material cost for a solid DF door should be around $100 to $150. Can you help us understand how the final (unfinished) product ends up in the $700+ range?ThanksScott.
Edited 10/26/2009 1:16 am by Scott
I can get nice VGDF wholesale at that $6 price. Figure a 3' x 6'8 door is 20 square feet at 1 3/4 thick for at least the frame components and you're up to 30 to 40 board feet before adding in waste and cutting. That puts mat'ls cost between $200 and $300.It is straightforward to build the door, but there is time involved and I want to be paid for that time. That $6 - $700 is not at all an unreasonable price for a custom door.
My clear alder door ended up costing me over $600, just in materials.
The 8/4 clear alder was about $5 b/f, the art glass panel was about $250, and the lockset was $120.
My labor was wayyyy much, just because I'm no professional, but even a pro would have had hundreds of dollars in labor, at least 8-10 hrs, maybe more.
Thanks. I figured you'd know.Scott.
If you have a shaper or heavy-duty router in a solid table, buy some cope-and-stick bit sets that can handle up to 1¾"-thick stock, and make your joints that way. If you don't, get a biscuit cutter or the Wolfcraft biscuit attachment for a 4" angle grinder, and use doubled #20 biscuit sets to make the joints.
Make the door just like a frame-and-panel cabinet door, only bigger of course.
The expansion/contraction factor isn't that big a deal except for glass lites; the door framing will expand and contract at about the same rate as the wooden door, and you usually leave an eighth to three sixteenths clear side to side, a bit more on the vertical depending on the type of weatherstripping you use.
If you glaze any glass into the door, use pieces of 3mm rubber screen spline in the clearance gap between the glass and the sides of the rabbets. The rubber spline will keep the glass centered and help cushion it from shocks when somebody slams the door. It will also compress as the wood door contracts seasonally, and will absorb that movement without transmitting it to the glass.
You need an eighth clear all round per 3 feet of width for standard ¼" glass, according to my glazier.
If you have the budget for CVG wood, that's your best bet; otherwise use clear or select...and be very selective about any select you use. ;o)
Dinosaur
foolish men call Justice....
there was an article in FHB 2 or 3 years ago, about the time I was finishing up building one the same way .. basically skip the mortise and tenon and make it out of 2 or 3 layers of 3 or 4 quarter stock, then alternate the layers so that if the rails are full width in one layer, the stiles are full length in the other. Similarly, reverse the cupping so that they keep each other honest. Keeping it flat wasn't hard at all, just level out your bar clamps, and do a practice run of your glue up. The article left the layers on the edge exposed, however I cut out an inset a piece to give it a solid look. The other comment about time was a good one, in the middle of a reno your not going to have time ..
Looks like you've got a great project going. How about backing up a ways and showing us construction from the beginning? I would love to learn more about the straw walls!You get out of life what you put into it......minus taxes.
Marv
I built one base on that article too. Birch plywood in the middle and fir on each side. It turned out very nicely but was thicker than a standard exterior door. A very easy and forgiving system.
I had fun making my boathouse doors myself.. I used black walnut timbers with black walnut plants T&G'd together as an overlay on the extrerior and Hard maple planks on the interior.. massively heavy doors! 6 ball bearing large hinges on each side (double doors) For the doors to the portico I'm making simple z braced panel doors with black walnut.
All the exterior timbers and trim are balck walnut.. The interior timbers are all white oak. For photos go to
39444.1
85891.1
94941.1
on the advanced search part over to your left.
Norm Abram made a very nice entry door as one episode of The New Yankee Workshop. http://www.newyankee.com
I have a copy of the DVD of the show, with scale drawings, still in its plastic wrapper waiting for the next home I build for myself. It's #0702D and can be purchased through the above linked web site.
I've built a few doors and re-built a few more, over the years. Norm's method really impressed me so I put that DVD on my Christmas wish list.
I had the same long-standing ambition for years, and finally built ours last Fall.
It has been through the 4 seasons here in the upper Snake River valley of Idaho, whose climate is very much like southern Alberta. Dry and cold in winter, hot and dry in summer, with occasional wet periods.
The door has stayed flat and true, but it is sheltered much like yours--not in direct sun or wind-driven rain for the most part--it's on the N side.
Mine is of clear alder, frame and panel construction in the Craftsman style, with an art glass insulated panel in the upper part.
My "teacher" for this project was a book I highly recommend to you: Building Doors and Gates by Alan and Gill Bridgewater. Great design ideas, and it walks you through the building process, step-by-step.
P.S. If you decide to go with the ledge and plank style door, which would blend perfectly with your handsome frame and timber style, go to the trouble of buying real door nails. There's only one company in the US currently making them, the Dormont Nail Co. of Massachusetts. The rose heads and double clinching make an authentic installation. I used this style door for my wine cellar.
Alright D,
I'm particularly interested in your take on this. Figure you're just the creative genius that would take a project like this on.
Aside from the carpentry, if you build your own, how do you handle something like low-e glass? Can you get that from somewhere and pop it in?
I can order insulated and low-e from a local glass shop. About $40 per sidelight-sized pane. I think the quote was $110 for lites to fit the uppers in a 4-panel door.
Thanks. Not sure why I assumed I wouldn't likely be able to source that kind of glass. I've got a great glass shop nearby. Sounds like a good excuse to stop in on the next lunch run down that way.Look forward to see what you come up with on your door project. That mousehole bed of yours is still on my list for when my daughter's old enough for her own bed.'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
>>>Aside from the carpentry, if you build your own, how do you handle something like low-e glass? Can you get that from somewhere and pop it in?Allow me to step in, seeing as I've gone through a summer with the glass industry.Yes, you can get custom cut low-e glass from any glass shop, but if you are dealing with any sort of volume try to get it directly from a manufacturer; you'll save a considerable margin.Depending on your climate, you might want double-glazed, low-e, sealed units, maybe even argon-filled. In this case you definitely want to deal directly with a manufacturer if possible. See my story in the middle of this thread:http://forums.taunton.com/tp-breaktime/messages?msg=123498.1Scott.
Edited 10/27/2009 12:55 am by Scott
I've been involved in few. Bally Butcher Block slab doors 8' tall and 6' wide pairs. Awesome.
Done plank on plank, done stile and rail ( never biscuits and never will) and T&G.
Gonna be making my own for my cellar and front entrance over the winter I hope.
I prefer thru tennon and wedges for stile and rail. Period. For plank or t&g , a layer of foil/bubble/foil insulation between faces is the ticket. As with raised panels, a layer between the panel backs.
I can get Low E glass and solar shielding here, IIRC there are 3 levels of Low E. I don't have the info handy, but my shop here hooks me up with just about anything made.
I am so dis satisfied with my Therma Tru or Jeldwen Lowes steel doors ( warped) I have little choice but to make my own, if I want a quality door that actualy seals.Spheramid Enterprises Architectural Woodworks
BIG ADVISE ON GLASS .. most shops charge by sq inches, but have a minimum order (50 - 75), before I knew that I built mine to have 3 seperate lites, that came to just under $200, had I used one SDL (simulated divided lite) it would have been about $80 .. plan ahead
Wow.Thank you everyone for all the quality feedback. I think I am convinced I would like to and can feasibly build a door now but just have to see how time goes. I could find a metal slab door at the second hand supplies store and hang it for now if I needed to delay the door construction. I had a Pella wood exterior door quoted, just to see what it would run.... $1500- $1700 Canadian for a pretty basic door!Quick question for you Sphere, I am considering a plank door. How did you put your reflective bubble pack in the middle of your door. I was toying with that idea myself as we have some really good reflective insulation manufactured here that runs R14 performance in 3/8" (Boeing and McDonald Douglas buy it for their aircraft hulls). Also, how did you do your tongue and groove?Regarding the request for more pictures of my house project showing the straw/clay infill process, go to our website http://www.harvesthaven.com and look under new buildings. I don't have any infill pictures up of the house yet but have some pictures of the infill process for a guest house we did last year as a beta project for the house. We will be running a straw/clay construction course again next summer if anyone wants to get in on it.Thank you again for all the great input!Mark
This may be hard to describe, but sandwich the insul ( about 1/4" thick) between the two layers of planks. At the edges bevel the planks and glue in a triangular filler that encases all edges.
It's like a hollow box, but a layer of the f/b/f inside. The inner and outer layers are t&g or glue joint routed to make slabs.
This isn't for every location, wild swings of humidity and less than perfect sealing all surfaces can make for havoc.
I did that method for a non climate controlled church, so indoor and out door temp/hum. was pretty well equal. We matched the pipe organ we built, hence the new millwork else where. It was Ash ( Fraxinus Alba) and stayed true.
There were quatrefoil cut outs glazed in the upper 1/3rd, that edging tied the inner and outer skins ( 3/4" thick) as one, as did the edge and top and bottom trimming, no glue, just nails, glue=cracks. Final thickness was 1 3/4".Spheramid Enterprises Architectural Woodworks
Hi Sphere.Thanks again. How much of an expansion gap, in any, did you leave in the T&G? What profile was the "glue joint" on that piece?Roger on the sandwich with beveled edges and triangular edging.I am a little worried about humidity differential between inside and outside. Our outside environment here is generally pretty low RH but I am putting clay plaster on all the walls inside which means a regulated RH at higher levels inside. Swings are not such a problem as this differential. I realize that is two different sides of the sandwich, which I don't know whether is good or bad. How did you attach the two sides of the sandwich together other than with the triangular edge fill? Did you have any intermediate cross members in between with fasteners bonding both faces together? If so, what kind of fasteners?Thanks,Mark
Nothing else internal, just the edges and glass borders. No expansion gaps, at least intentional.
Plenty of sealing ALL edges is the key. IIRC we used glue, Titebond, as a sealer on the internals. Quicj, easy, and already on hand. The ext. got Conversion Varnish, both interior and exterior.
The ash was plenty stable.Spheramid Enterprises Architectural Woodworks
Thanks Sphere. My brain is in gear.Mark
f/b/f? Like this? http://www.insulation4less.com/Insulation4lessProduct-14-Reflective-Bubble-Reflective-RBR.aspx
Regarding insulation, I'd be more inclined to recommend 1/2" polyiso which you know will give about R 3.5. I'm always concerned with the foil-faced bubble wraps and their claims of R-value, much is dependent on their foil faces acting like a radiant barrier. In a sandwich, with the foil in direct contact with wood, the foil simply becomes a thin conductive layer. No reflective or radiant value whatsoever.This 3/16ths inch thick bubble wrap claims an R-value of "up to 14.1", I'd venture that a bubble wrap in a sandwich assembly would have an R-value closer to plain air, which is about R-1 per inch, or roughly R-0.25 for this 3/16ths inch product.Totally my supposition, and I don't want to derail this thread off door making and on to insulation theory. But if I had the need to sandwich a layer of insulation in a door assembly, I'd choose a rigid foam board like polyiso over a bubble wrap.
>Totally my supposition,<
no sweat and I agree. I haven't did any drawing on this yet but wonder how easily 1/2 insul board would be to incorporate into the floating panel as I'm interpreting Sphere's suggestion.
This whole door building thread I find fascinating and I'm thinking it's a service I can offer once I make a few for myself as experiments and such.
Hi Mongo.I am not sure if the contact with the door necessarily annuls the reflective value of the insulation (if somebody out there that is an expert on this can correct me on this, please do). The stuff we have used that is manufactured locally though is different from the other stuff on the market in two ways. It is a sprayed on aluminum (like the inside of a potato chip bag) rather than rolled aluminum which makes it an non-conductor (rolled aluminum will conduct current and heat, this stuff apparently doesn't) and secondly, there is a high-tech thermal break membrane placed between TWO layers of bubble interior. This supposedly makes the difference. We wrapped the current farmhouse with this stuff several years ago and sided over it (5000 square feet). We went from running two furnaces all the time in the winter to one furnace some of the time and the house feels like it has air-conditioning in it in the summer. I can't prove the claims of the manufacturer (though I know the inventor and think he is legitimate) but have seen the impressive results first hand.Mark
I don't use it for r value. More as a spacer between the 3/4" panels and if they would split or crack, have something behind to keep things copacetic.Spheramid Enterprises Architectural Woodworks
Back-to-back panel construction is a great way to minimize stress on panels. The inside panel harmonizes with interior conditions, the outside with outside. That's how I'll be building this door. I have nine yards of concrete being delivered Friday for the front porch. Wish me luck. If you don't see me posting Friday night I might be hanging out with Jimmy Hoffa.
Oh, the T&G, I have wedge T&G bits for my router, and for straight T&G I use a dado head for all cuts, on a Table saw or (GasP) a Radial arm saw.
If a bevel and bead is wanted, you can use a single bead of a triple bead screen moulding cutter on a moulding head, just bury 2 beads in a sacrificial fence. Champher the groove side with champher bit, and the tongue can be done with a straight cutter moulding head ( the insert cutter type, Sears) tilted at 45 degrees, or sawn with a tilted blade. If you opt to skip the bead.
And yes, I've hand planed many a foot of bead, it's not a chore for a door. A whole floor (exposed underside) or wall panel, the power tools come out.Spheramid Enterprises Architectural Woodworks
Speaking of hand planing... Saw this on the local craigslist. http://portland.craigslist.org/yam/tls/1435609956.html
Life is Good
Nice..decent price as well.
I have the Craftsman version, from way, way back..I guess when the Stanley Pat.expired.
And many wood bodies, some Sandusky and some so old and home made, that they are just stamped with intials.Spheramid Enterprises Architectural Woodworks
Cool. Thanks for the info. Had to scratch my head for a second to figure out what you were talking about with the wedges. All I could think of at first was a furniture style where you wind up with the proud tenon nubs, and I couldn't figure how THAT was going to work on a door. LOLLook forward to seeing what you do on the cellar door.'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
The motice is dove tailish, and either slot the tennons and split them near the ends with the wedge, or leave them sq. and taper the wedge on one side only and fill the "gap" that you chiseled the mortice to.
Most old doors were wedged tennons.
A Fox wedge is another critter, but it's a one fit , one time deal, a blind wedge. And they are tricky.
Cellar door is gonna be Heart pine as old as the house..I ihave some left from some demo here. Probably just like I described a post back. It's not a finished cellar, just a really big 12x44 concrete box with one door from out side and no access from inside the house. No vents, no windows.Spheramid Enterprises Architectural Woodworks
This was in BT file so did not have to take new pix, kinda washed out pix byt you can get the idea.
Except for the lead came and key bolt lock, it is all surplus material,
3" thick oak from pallets, raw glass from garage sale, self carved.
This one is about 25 YO, no warping or crack, finish polyurethane over watco (both from local wastemobile) on the inside and clear epoxy on the outside. Mortice and tenon with bolts thru the corners.
Buy both his video and the plan. Use the same stuff he did, which if I recall correctly, was mahogany. If you can get pattern grade planks, buy them.
Nice house you're doing. The blown glass lites might look good with your design.
"A stripe is just as real as a dadgummed flower."
Gene Davis 1920-1985
You can definitely build your own if you plan it out. I've only built a few myself. If you do build from solid wood you will need to make friends with someone with a jointer and planer. Mill the wood to rough sizes, let it sit for a week in the shop, then joint/plane/mill your pieces. As for lites, talk to a few glass shops. A good shop won't have any trouble making you up low e units any size/shape you want. Maybe post over at Knots, those guys do more of this type of work.
Here's a picture from the shop I used to work in. Old growth douglas fir reclaimed from an old bridge, no finish on it in the picture. We gave the glass shop a couple of templates and a week later we had the sealed units. Not much difference in price compared to a square unit.
I love what you're building, one of my favourite styles.
Beautiful doors.
Life is Good
Paul,
Just wanted to circle back around and see if you found enough pics to start a thread on your door build.
BTW, I was just flipping through the Kitchens/Baths issue and realized your basement bath/sauna was featured there. Congrats on the nice work. Really liked that transom in the shower.
Best,
Steve
Steve,
I already totally spaced on getting that thread together, I've been in the process of relocating so my life has been filled with boxes and more boxes, as well as 10 hour days working before moving said boxes!Thanks for the kudos on the article. It was the first project I've had published and I thought the project had turned out great. Really cool clients. I just went by there the other day to do another quick project for them and I went back down to the basement; it was fantastic. It's a pretty great feeling to walk into something that turned out really well. They kind of just let me go at it with design and building. They just wrote the checks when I asked for them. It's nice to have that kind of relationship with clients; they were willing to pay to have it done well, and I wanted to do it well!I wasn't actually sure about how the transom would look, but I thought it made sense for airing the steam out after they use the steam shower. They've ended up hardly using it, but I think it looks pretty cool.I put down on my upcoming scheduled projects list to get those photos together for you. They're just sitting in my iPhoto program, but I haven't taken the time yet to put them into a cohesive thread. Will do so after the big move.Enjoy the thanksgiving time...Paul
Paul,No worries at all. I remember the last move and I know digging up photos would have been the last thing on my mind!Clients like that always make life more enjoyable, no? I saw as well that they used your shower as the backdrop for the call for entries for the 2010 K&B issue. Might see if you can get a copy of that for your portfolio.Best wishes for a happy Thanksgiving to you and good luck with the move.Best,
Steve'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
StrawClayMark,
Wow! awesome place! I say 'go for it' about the custom door. a place like that needs a door to show off the uniqueness of the house.
I came to the same conclusion about the lack of style when it came to doors. there was nothing that even caught my attention.
So I asked the trim carpenter if he wanted to make a front door. I wanted mahogany -- with a diamond window --- that was my only requirement. Told him to do whatever design he wanted. (He was good and i trusted him). Attached is the photo (door to right of main entrance leads to garage and is made of Ash)
we used oil stain called Flaming Australian (or something). The house is in New York State about 12 minutes from Lake Placid. As you can see, it is protected from the weather a bit, but the winters are very cold.
The door warped a bit last year (hard to throw the lock) when the spring came the humidity jumped quickly. But we love it. i must weigh 500 pounds.
I'm having all the doors in the house custom made (photo attached) --- interiors are of pine (spruce warps more). We're matching the bottom half of the door with whatever design that goes with that room (i.e. beadboard to match the beadboard along the bottom half of the room.
If they warp over the years, I don't care. I haven't dug into to learning doors because I'm too busy making cabinets --- but I'll learn.
Your place is awesome -- it needs a great custom built door --- just do the yearly oil change!
Regards,
Tom
Do you know the construction? Are those planks over some sort of a core? Does the inside match?Thanks, JohnPS Great door
Hi TJ.Thanks on the compliments. I just put in another long day on the standing seam metal roof today. We opted to build angular prow gables on the house. They look great but try doing standing seam metal on them!!! That takes a little math to calculate where the rib will fall when building out from the prow back into the roof while at the same time plotting the angle of the prow against the parallel lines of the roof. If the ribs don't line up from the prow above and the hipped gable below where they meet, you have to take off the metal and try again! I will have to put up some pictures when we are done. It is rustic metal roofing. 22 gauge cold rolled metal the rusts to a beautiful orange and brown patina.Thank you for the door encouragement. I have come to the same conclusion as you did. Just need to find the time to do it!! I have a million jobs to do before winter gets here any day now!Regards,Mark
Glad to see this thread brought back to life.
I just finished framing and sheathing the vestibule today, so the dimensions are set. It'll be a 3-6 by 7-0 door. 2-1/4" thick.
Pretty much set on mahogany. I have to see what the yards have for mahogany, that might drive my methods of construction. The two good places near me ("near me" meaning they are within 30 minutes) have 8/4 max thickness.
If it's not going to be solid stiles and rails, I might use a 3/4" medex core and skin each side with 3/4" mahogany. The panels will be split for independent interior versus exterior movement.
Either a 4-panel or a 5-panel. I'm leaning towards five.
