Built-up beams — construction detail
| Posted in General Discussion on April 20, 2001 10:56am
I’m planning on using 3×8 (two 2x8s) built-up beams in the the construction of a deck.
My question: must the beams be constructed with spacers as a sandwich, then placed on top of the posts, or can I place one 2×8 on either side of the 4×4 post and through-bolt them to the post and each other with two bolts per post? This would leave a 3½” space between the 2x8s. Is this an acceptable design?
thanks.
  1. FXDP_ | Apr 20, 2001 10:56pm | #1
    I'm planning on using 3x8 (two 2x8s) built-up beams in the the construction of a deck.
    My question: must the beams be constructed with spacers as a sandwich, then placed on top of the posts, or can I place one 2x8 on either side of the 4x4 post and through-bolt them to the post and each other with two bolts per post? This would leave a 3½" space between the 2x8s. Is this an acceptable design?
    thanks.
Picture-Perfect Pergola
