Bulkhead door
Skylight | Posted in Construction Techniques on March 27, 2009 01:45am
I’m building a bulkhead door, similar to the one shown in FH#171. I’m using T&G 1×6 cedar boards, I’m wondering if there is some way to seal the seams where the T&G meet. The bulkhead slopes at about a 4 pitch. I intend to paint the door, but I’m not sure that will seal it. Should I be concerned? Any ideas?
ciao
    EricPaulson | Mar 27, 2009 02:56am | #1
    I built something similar and glued them together with Gorilla glue. Got a little ooze and cut it off the next day.
    There is a little leaking, some from the joints and some through knot holes.
    You could try Azek, but it might get heavy.
    1. Skylight | Mar 27, 2009 04:57am | #2
      thanks! some input is better than none. I think it's a tough subject, and maybe not a good design.ciao
  2. allaroundcobber | Mar 27, 2009 05:31am | #3
    you could build it out of plywood with a raised lip and wrap it in metal.
    Did one this winter and it came out great and should last a long time.
    Moe
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
