will be applying slate to the face of my fireplace in the near future and am hoping someone has a proven technique for rounding over?
can I get somewhere w/ my 4″ grinder and belt sander?
also ideas in the event I go w/ an arch (slight) as opposed to straight across
I await many thanks john
Listeners write in about greedy dormers and shop class and ask questions about steamy storm doors, fireplaces, and insulating a basement.
I just cut up a bunch of old blackboard slate and laid it down on my kitchen floor. It's sort of a soft and brittle material, so sanding should work beautifully, but you might risk chipping it up with a grinder. Also, if trying to use a belt sander, you probably wouldn't want to go against the grain of the stone--that'd probably chip it as well.
You can use a diamond blade in a side grinder. Go easy. And you can hit it with silicon carbide sandpaper (the black wet/dry stuff) to take out some of the scratches and create a radius edge. Regular sandpaper works too, but it might not last as long. I think I wouold use a palm sander rather than a belt sander ... better control.
I have only done one job in slate slab, I usually work with granite. For whatever stone I am working with I use Silicon Carbide sandpaper in 7" discs and spin them between 2000 and 4000 rpm. For slate I would probably just use 60, 120, and 220 grit.
Rubbing your hand on the edge to transfer a little of the oil on your skin should help darken the raw, fresh sanded look. If you plan on adding a sealer or color enhancer that should also even out the colors nicely.
Slate is so soft that any abrasive should work but silicon carbide is likely to hold up longer working with stone. Not a big deal for a one time project though.
karl
fastone & tuffy
many thanks
I'll be giving it a go today
How did it turn out?
GoodLuck
"can I get somewhere w/ my 4" grinder and belt sander?"
Yes.
Buck Construction
Artistry In Carpentry
Pittsburgh Pa
the bullnozing is being put off until I do the mstrbdrm fireplace
this one I've won out over rest of design committee (DW) amd will do slate on floor / hearth and face fireplace w/ riverrockwe are putting vermont castings glass doored faux log gas heater in a insert esque situation and hopefully I have gained elevation space replacing the 2" Pennsylvania bluestone w/ 1/2" slate so the unit will fill the opening of fireplace and not encroach too much in roommasterbdrm fireplace shares chimney / different flue gets addressed in coming weeks - bullnose time thank you all for youir input
Any cheap diamond blade in a 4" grinder will cut your slate like butter. Some slate is soft enough that, for a small job, you can do your roundover with a rub brick, you know, the carborundum block with the plastic handle on it.
Bruce
Between the mountains and the desert ...
