Hi All as a small general contractor I am having difficulty finding computer software that is specificaly designed for my business. Does anyone have any recomendations.
Learn the specific guidelines for location, spacing, and clearance for optimal safety.
Accounting or project managament?
A little of both. In theory I start a bidding process, win the job and it then becomes project management
I like doing the bid and contract budget negotiation in Excell then move it into QuickBooks for job costing and then ack into Excell for data mining. I know there are packages that do it all but I like the direct approach of keeping it simple.------------------
i use the older version os this one...
http://www.synapsesoftware.com/
Mike can you explain a little about the benifits of the software you linked to and how you use it?
the one i linked to is BuildWorks
the older version i have is GC Works
they both use templates
in Build Works they use QuickBooks Pro & Excell
in GC Works they use QuickBooks Pro & Claris Works
you enter customer information, do the take off & estimate on the template, and it prints a Proposal, Change Orders, Actual vs. Estimate comparisons, SubContract Agreements, Purchase Orders...... everything is linked to the basic document..
and the basic document ( the takeoff ) can be one page ( with labor-materials-subs & equipment ) or it can be the 12 page take-off
they have different levels aimed at Remodelers than the version aimed at new Construction
if you use it , it becomes almost impossible to forget items.. and it is very fast
i'm pretty sure they have demo disks
WMike Smith Rhode Island : Design / Build / Repair / Restore
Right now I'm just doing Excell-MS Project-QuickBooks Pro. I have UDA Construction Office and decided not to upgrade when I upgraded systems last year. I have used Timberline. Just start looking most companies will let you use trials for a while before purchasing. I also recommend checking out JLConlines computer solutions for more ideas.
Jason
How big of a small general contractor?
If you are 2-3 guys running one or 2 projects at a time and wanting something cheap and simple, then Quicken has a Home and business product which is pretty powerful for an easy to use program.
I have several clients using it to track projects, and expenses all in one.
But these are 2 man hvac shops, etc.
A medium to large guy named Alan, not an ambiguous female....
NOT that there is anything wrong with that.
