Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
What is the preferred fastener spacing on a drywall butted seam ? (assume horizontal layout with the butt seam falling on the lengthwise center of the stud) If there is a difference for nails versus screws, please indicate.
Many thanks,
Steve
*Go 8" and use screws for everything but cornerbead.
