Buying round drywall sanding gear
xxPaulCPxx | Posted in Tools for Home Building on February 25, 2006 07:09am
I’m going to order the new round drywall sanding disk setup that was reviewed in the last FHB magazine.
http://www.all-wall.com/acatalog/Radius_360__Drywall_Sanding_Tool3.php
My question is this:
What sandpaper grit should I get?  They don’t sell a variety pack, just packs of 25 pieces of each grit from 80 to 240.  At $21 a pack, I’d like to preferably buy just one, but I’ll get two if it’s really necessary.
Also a CRX fanatic!
    MarkH | Feb 25, 2006 02:27pm | #1
    Just one, 150 grit.  A 120 or so would be faster for first sanding.
    Why don't you contact them and ask why they dont have assorted packs?
    Edited 2/25/2006 6:31 am ET by MarkH
  2. calvin | Feb 25, 2006 03:54pm | #2
    paul, a little depends on what you use for your last coats.  Plus 3 is softer, don't need too coarse a paper or you'll end up with scratches.   Reg. bucket mud is harder, topping a bit softer.  Give 'em a call and see what they recommend for the various products.
    Quittin' Time
  3. BoJangles | Feb 25, 2006 08:14pm | #3
    I have several of those sanders.  They are wonderful.  I stock two grits.  100 & 150.
    As you say, the 100 is good for initial knockdown of harder compounds.  The 150 is all you will need if you use "Plus Three" as your topcoat. ( and why would you use anything else???)
    I use 150 about 90% of the time.
    JDRHI | Feb 26, 2006 12:15am | #4
    I'd buy at least two....100 and 150 grits....you'll be kicking yourself the day you've got the tool, but not the grit.
    Remodeling Contractor with no ties to the Glass City
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
