C purlin receiver channel overhang
TucsonDean | Posted in Construction Techniques on June 26, 2024 06:46pm
Hi I’m looking to build a 15’ x 53’ carport on the side of my house. The construction will be 8 in c purlin and receiver channel. My question is that where I thought I would have a post there is a power utility line underground. I’m wondering if I can overhang a 14 gauge 8” x 2.5” @ 20’ receiver channel to avoid having a post (red in the sketch). The carport will attach to the house which is slump block. 12 ft of receiver channel would attach to house with masonry bolts, 8 ft would overhang. Does this sound feasible?
    ct_yankee | Jun 29, 2024 10:24am | #1
    More info needed.
    Regional names for products (like "slump block") need to be better defined.
    Actual brand of steel channels would be helpful.
    Your location matters - will this have to be designed for snow loading or just heavy rain loading? Pitch required for drainage?
    Cantilevers greater than 25% of the main span (i.e. 0.25 X 12' = 4') general become problematic.
    Looks doubtful that it will be adequate.
  2. TucsonDean | Jun 29, 2024 07:08pm | #2
    Thank you, I’m going to add a post. Seems wiser to actually locate the utility line, then add a post out of the way.
