Cabinet grade ply for baseboard??
curley | Posted in General Discussion on March 12, 2007 03:49am
I need a tall baseboard. Priced poplar, it was $1.50 foot. I plan on painting the board white. Is it o.k. to use cabinet grade plywood for baseboard. I figure I need a 8″ baseboard so I can get six pieces out of a sheet at $40, then router an edge on the top
would that be an exceptable practice??
  1. WayneL5 | Mar 12, 2007 03:56am | #1
    The edge would look rough, and routering would not help.  The exposed end grain will still show.
    If you want a square edge you can apply iron on wood edge banding to the plywood.  It makes a nice finish.
    You could try MDO as well instead of plain plywood.
  2. Stilletto | Mar 12, 2007 03:57am | #2
    Probably,  instead of routing an edge on the top use a two piece base.  Your plywood rip and a 1/2" quarter round on top.  Or a small cove moulding.  Trying to route and sand plywood is a pain with less than favorable results.
    This will also help fill any voids or imperfections in the walls due to flexibility of the small moulding.  Less painters caulk is a good thing.
  3. MisterT | Mar 12, 2007 04:41am | #3
    Painted >>>MDF
    Wars of nations are fought to change maps.
     But wars of poverty are fought to map change.
  4. FastEddie | Mar 12, 2007 05:06am | #4
    mdf is a waste of money for base.  it gets too much abuse and will chip very easily.  Plywood will work well, but as other have pointed out the plys will show badly, unless you take a whoile lot of time to fill and sand.  I second the idea of using a small piece of trim on top to hide the plies and add some detail.
    1. curley | Mar 12, 2007 05:20am | #5
      I think thats a great idea, never gave that option a thought.
      thanks
      ps this is going into my kids room. I figure its going to get some reall abuse
      1. pacificsbest | Mar 12, 2007 05:54am | #6
        There is an article here on finehomebuilding about plywood Trim:
        http://www.taunton.com/finehomebuilding/how-to/articles/beautiful-trim-plywood.aspx?langtype=1033&ac=fp
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
