Can a Fernco fitting be left….
NietzschesMustache | Posted in General Discussion on July 7, 2009 06:18am
…behind the drywall, in the ceiling? I have to transition from 1 1/2″ PVC to 1 1/2″ galvanized drain pipe.
If not, how do I get the piece of galvanized unstuck from the 4″ cast iron so I can attach the PVC directly? The galvanized is in bad enough shape that it might break.
    IMERC | Jul 07, 2009 06:27am | #1
    not here in horizontal...
    yank pipe till you go vertical or get to a riser stack...
    use a donut inside of the iron hub...
    http://www.fernco.com/plumbing/donuts-o-rings
    Donuts
    Sewer pipe compressions joint sealers.
    WOW!!! What a Ride!
      NietzschesMustache | Jul 07, 2009 06:39am | #2
      Thanks, but can't do it. I have about 8" of horizontal pipe left, and I can't get to the vertical stack.
        IMERC | Jul 07, 2009 06:44am | #3
        how about as best as ya can give us better discripition of what ya have...
        WOW!!! What a Ride!
        IMERC | Jul 07, 2009 06:53am | #4
        this one maybe???
        Multi-Tite Pipe Gasket
        Pipe gasket for service weight cast iron pipe.
        WOW!!! What a Ride!
          NietzschesMustache | Jul 07, 2009 08:00am | #5
          Okey. Everything is horizontal, seen from below:
            IMERC | Jul 07, 2009 08:15am | #6
            pull the galv and use this donut....
            lube the donut on insde, chamfer the end of the squarely cut PVC a tad... push the PVC stub into the donut using a scissors jack from yur car... use a repair coupling off of the stub to go where ya need to...
            WOW!!! What a Ride!
          2. mrfixitusa | Jul 07, 2009 02:56pm | #8
            good advice
            popawheelie | Jul 07, 2009 06:40pm | #10
            So we are looking up at the cieling in this picture? Just to be clear.
            That is a cieling joist with 1x4? subflooring on top of it.
             "There are three kinds of men: The one that learns by reading, the few who learn by observation and the rest of them have to pee on the electric fence for themselves."Will Rogers
        IMERC | Jul 07, 2009 06:24pm | #9
        sure ya can... somebody put the galv in after the joist was installed...
        WOW!!! What a Ride!
  2. Marson | Jul 07, 2009 02:17pm | #7
    Yes, you can do that where I live. You have to use what the plumbers call a "mission" coupling (which I think is a brand). The metal band is crinkled so it doesn't buckle when the hose clamps are tightened. http://www.missionrubber.com/Products/NoHubCouplings.php
      BillHartmann | Jul 08, 2009 08:46am | #15
      The generic name for those is Shielded and Fernco also make that style..
  3. Shacko | Jul 07, 2009 11:01pm | #11
    That is a screw joint, you should be able to unscrew it with a pipe wrench, put in a male pvc adapter, short piece of pvc and a glued cap, should be easy, luck.
    "If all else fails, read the directions"
  4. betterbuiltnyc | Jul 08, 2009 12:57am | #12
    No doubt the galv won't back out, right?
    Cut it close to the CI, then score the inside with a sawsall...slowly, and not on the bottom where it's 'wet'
    Knock it out with a cold chisel. Insert PVC transition, with dope and tape.
      NietzschesMustache | Jul 08, 2009 01:44am | #13
      Thanks, everyone. Done got it did. I used the edge of a half-round file to get the remaining pipe loose, much as betterbuiltnyc recommended (couldn't get the RS up there between the joists).
    2. McPlumb | Jul 08, 2009 01:45am | #14
      If warming the cast and applying a pipe wrench to the galv. didn't bring it out.
      That would be the next step.
      I reccomend a fine tooth blade and sawsall with slow variable speed.
      And lots of patience.
      Good luck
