Can exterior grade plywood be painted an
BigMish | Posted in General Discussion on May 20, 2009 08:21am
I have a porch and some of the siding is plywood. I’d just a soon keep it but the paint on it looks awful like painted plywood always seems to. Is there some paint/primer combination I can use to keep the plywood or should I just give in and side it with wood?
Thanks, Mischa
  1. Danno | May 20, 2009 10:47pm | #1
    There is a plywood called MDO (medium density overlay) that is made to be painted (has a phenolic resin-impregnated paper surface) for future reference, but since you have what you have, I can't give you any real good advice. I would think you need something to hide the grain and that would make the hard and soft grain not absorb paint differently. I think pimented shellac as a base coat would help a lot--a couple coats of that and then a good top coat (or two).
    I was also thinking that something thick like varnish to hide grain, but I think that enamel is basically varnish with pigment added, so you might try an enamel over an undercoat that is made especially as a primer for enamel. (Called, surprisingly, "enamel undercoat.") I'm sure there'll be more and better advice coming!
  2. DanH | May 20, 2009 10:56pm | #2
    Most plywood can be satisfactorily painted. As with any other wood surface, though, poor results are achieved with poor preparation and poor materials.
    Raw (and clean/dry!) wood should first be primed with a good exterior primer (I prefer alkyd), then painted within a few days with a good satin or semi-gloss exterior paint (latex or acrylic).
    Even with good preparation and materials, though, poor results may occur if the plywood is not exterior (or at the very least "exposure" 1 or 2) plywood), or if there is moisture "driving" from the inside.
    Also, difficulties will arise if the surface has already been painted without primer -- scrape off what you can, prime, paint, then do it again in a year or two when more flakes off, until the entire surface has been primed.
    As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
    Dinosaur | May 20, 2009 11:10pm | #3
    Strip, sand, and then prime with alkyd primer and an alkyd colour coat. I'd use high-gloss, but that's up to you. An alkyd high-gloss paint tends to 'film-sheet' very well if applied at the right temperature, and that will help hide the plywood grain you object to.
    Dinosaur
    foolish men call Justice....
Two Ways to Test Windows
  • The New Old Colonial
