Can I cut hardi with a hole saw?
mwgaines | Posted in General Discussion on September 26, 2007 03:46am
Planning to install my first tile floor soon and I’ll probably be using Hardiboard or similar product under the tile. I used a 5″ hole saw to cut the toilet waste through the subflooring. I’d like to trace the outline of the hole onto the cement board from underneath and repeat the cut with the same hole saw to keep things neat. Will the same hole saw handle that or will I need a jig saw and special blade?
Thanks for any assistance.
New knowledge is priceless.
Used knowledge is even more valuable.
  1. alwaysoverbudget | Sep 26, 2007 03:58pm | #1
    you can use the hole saw but it will dull the heck out of it,and 5" hole saws aren't cheap,i would just grab the sabre  saw and a couple blades and cut it,you might waste 2.00 worth of blades but oh well,better than a 40.00 hole saw.  it will cut pretty good with about a 8-10 tooth  blade. larry
    why pay someone to screw it up,i can do it for free....
      MarkH | Sep 27, 2007 02:20am | #6
      Hardi is sort of like an abrasive stone, I would not waste my holesaw, but a grit edge (or diamond edge )holesaw would be OK.
    2. mike4244 | Sep 28, 2007 01:50am | #13
      Bosch makes a sabersaw blade for cement board or tile. Tungsten carbide I think. I have cut at least  100 lf of hardiboard with the same blade,it's dtill in good shape.
      mike
    xxPaulCPxx | Sep 26, 2007 07:34pm | #2
    Yes it will... once, maybe twice.  I ruined my 4 1/8 hole saw on some hardy running a pair of lights.
    Make a series of thin pie slices with an angle grinder, then snap them out.
    Also a CRX fanatic!
    If your hair looks funny, it's because God likes to scratch his nuts.  You nut, you.
  3. dug | Sep 26, 2007 11:41pm | #3
    I make that cut with a 4'' grinder and tile blade.
     Cut an octagon around the outside diameter. The tile will cover it up.
      I believe in being neat but in this case it will only cost you time and money.
     Once the tile is down no-one but you will know that it was'nt a perfect circle.
      Dug
  4. mwgaines | Sep 27, 2007 12:49am | #4
    Thanks guys. I'll take your advice.
  5. MSA1 | Sep 27, 2007 01:08am | #5
    Dont cut Hardi with anything you ever want to use again.
    I use a paint stick that I have multiple holes drilled in for different sized holes, then cut the hole with a sawsall.
    DDay | Sep 27, 2007 03:34am | #7
    Take a look at Ditra which is the flooring product made by the company (Schluter) which makes the Kerdi that you hear about here a lot. The ditra comes in rolls, its about 1/8" thick cuts with razor and is about the same cost as hardie, and others. Check out the link and do a search here and on johnbridge.com. The product in combination with the kerdi for the seams can make the floor completely waterproof.
    http://www.schluter.com/2080.aspx
  7. alhimprov | Sep 27, 2007 04:34am | #8
    Use a rotozip with a tile bit.  It works great.  Don't try to cut the floor tile with this bit.  It will work on wall tile though.
  8. Jerry18 | Sep 27, 2007 05:07am | #9
    4" diamond blade on an angle grinder. Very dusty; very fast.
    Jerry
  9. User avater
    Sphere | Sep 27, 2007 03:13pm | #10
    Just run the HS in reverse, it'll lose a little of the set of the teeth, but easily touched up with a thin disc in a grinder.
    "If you want something you've never had, do something you've never done"
    1. Philter | Sep 27, 2007 07:04pm | #11
      I've just used a Bosch jiggy blade with grit? edge, SMOOOOTH AND fast!
      Six holes and looks like no wear....
       "If 'tis to be,'twil be done by me."
        Sphere | Sep 27, 2007 07:38pm | #12
        Yeah, they work pretty good. Disposable too.Spheramid Enterprises Architectural Woodworks
