Can I eliminate a floor supporting post under my cabin?
kyrral | Posted in Construction Techniques on February 9, 2013 01:16am
I am trying to make a room under my cabin and one of the floor support posts is in the way. It supports 2 x 6 floor joints that run from foundation to foundation.  What I’m wondering is if I could run a 4 x 4 at right angles to the joints and create new floor supports at the end of the 4 x 4’s. The span would be 10 to 12′. As long as the 4 x 4 didn’t bend wouldn’t this be sufficient?
  1. DanH | Feb 09, 2013 01:32pm | #1
    Yes, if the 4x4 didn't bend it would be sufficient.  However, based on your description, the 4x4 will almost certainly bend to an unacceptable degree.  A 4x4 is less stiff than a 2x6.
  2. calvin | Feb 09, 2013 03:18pm | #2
    kyrall
    4x4-NO WAY.
    If you're going to eliminate something, put something back that'll hold it up.
    cabin or not.
    Figure the span and load and install a beam that will hold it.
    BossHog | Feb 09, 2013 05:54pm | #3
    A 4x4 is nowhere near being adequate for that.
    The rough rule of thumb is that you need an inch of depth for every foot of span. So a starting point for your header would be 10 to 12" deep.
    1. junkhound | Feb 10, 2013 07:21pm | #4
      Aw guys, U Bing hard onna guy, after all, he did not SAY the 4x4 wud B wood, eh?
      A full 4x4 12 ft section of 4340M steel hardened to 56 Rockwell C would do the trick just fine - cost more than his cabin though, and weigh less than 1/2Ton.
      A 4eye9.5 would work too, 12 ft would only cost him about $120 or so and be at least as strong as a hem fir 2x12
  4. kyrral | Feb 11, 2013 06:03am | #5
    What is 4eye9.5? Also suppose I tripled the 2 x 6'S
    Googlle doesn't recognize 4eye9.5.
    What would be the effect of tripling the 2 x 6's  from foundation to foundation? With enough 2 x 6's bolted together couldn't I theoretically eliminate a supporting post?
    1. DanH | Feb 11, 2013 07:20am | #6
      What would be the span that direction?
      1. kyrral | Feb 11, 2013 09:33am | #7
        I will measure today and answer tomorrow.
        1. kyrral | Feb 11, 2013 04:23pm | #8
          12', twelve feet
          12'
    2. junkhound | Feb 11, 2013 09:21pm | #9
      aka 4 x 9.5
      http://www.engineeringtoolbox.com/american-standard-beams-d_1320.html
      1. DanH | Feb 11, 2013 09:42pm | #10
        Actually, I suspect that a piece of 4x4 square tubing could handle the load just fine.
        1. kyrral | Feb 15, 2013 01:32pm | #11
          What thickness 4 x 4?
          I checked and I could get 1/8th or 1/4th walls. Also I beams in either steel or aluminum. A 12' section 1/4' wall weighs about 150.
          1. florida | Feb 15, 2013 03:51pm | #12
            Whatever Dan says, he's an expert structural engineer. Or you could just roll your dice.
          2. junkhound | Feb 15, 2013 09:36pm | #13
            Roughly, the 1/8" wall is
            Roughly, the 1/8" wall is equivalent to a single 2x12 of wood, the 1/4" wall a double 2x12
Versatile Vise
