Can I put OSB directly over this?
mwgaines | Posted in Construction Techniques on February 26, 2007 11:18am
Will soon be installing brick veneer. Blackboard is 40 years old and provides no strength for the framing. I’d like to add a layer of 7/16 OSB directly over the top of it. OSB would then be wrapped prior to installing new windows and doors.
Any problems with this idea?
New knowledge is priceless.
Used knowledge is even more valuable.
    PeteDraganic | Feb 27, 2007 01:03am | #1
    No problems that I can think of.
    When you're this good, EVERYONE wants a crack at you!
    http://www.petedraganic.com/
    rjw | Feb 27, 2007 01:15am | #2
    Is there a way for the water and water vapor which will get in (remember, brick and mortar are porous) to get out "quickly" enough?
    OSB is "mold candy"
    With my mouth I will give great thanks to the Lord; I will praise Him in the midst of the throng. For He stands at the right hand of the needy, to save them from those who would condemn them to death.
    - Psalms 109:30-31
      mgard38 | Feb 27, 2007 01:36am | #3
      I Would Use Advatech instead of osb as it is more water resistent.Than it Would be less ap to mold
      Edited 2/26/2007 5:58 pm ET by mgard38
      PeteDraganic | Feb 27, 2007 02:11am | #5
      Bob, is there any documentation that supports this claim?
      I would think that OSB would be more mold resistant than CDX or other typical plywoods.
  3. BillBrennen | Feb 27, 2007 01:42am | #4
    Problems? OSB over the beaverboard will make things stronger, but not as strong as if you remove the old stuff and OSB right on the framing. Use long enough nails and you should be fine. If I suspected any water intrusion in the last 40 years I'd want to tear off the old sheathing and have a look before covering it back up.
    Bill
      PeteDraganic | Feb 27, 2007 02:14am | #6
      Certainly it would be stronger with direct contact to the studs but that difference would likely be negligible.<!----><!----><!---->
      You would, however, lose an insulating component of the wall in removing the fiber board.<!----><!---->
      I don’t think that the removal of the existing fiber board would be warranted under normal circumstances.
  • Townhouse Transformation
