Can I rebore a 2 1/2″ backset to a standard backset?
user-514039 | Posted in Construction Techniques on November 14, 2012 09:57am
I have a house full of doors with 2 1/2′ inch backsets and didn’t realize it until I had filled, primed and painted all of them.  Of course, I hadn’t saved any of the original doorknobs I took out.  Can I rebore the holes to fit a 2 3/8″ backset?  I’m afraid it will make the hole too big.
    hammer1 | Nov 14, 2012 11:54pm | #1
    Quite a few, if not most, strikes/latches are universal for either 2 3/4" or 2 3/8" backsets these days. 2 1/2" would be unusual but the rosette may cover the difference if that's what you have.
    See the specs on this Schlage for example.
    http://consumer.schlage.com/Products/Pages/ProductDetails.aspx?ModelNumber=F10%20BEL%20626
    1. DanH | Nov 15, 2012 07:34am | #2
      Schlage apparently has some styles that are more or less fully adjustable (requires some extra parts apparently).  However, they are mostly commercial designs.
      You might see if you can get replacement latches in the length you need, to fit the brand of knob you want.
      But I'd first see if the style knob you've picked will cover the 1/8" offset.  If not, picking a style with a slightly larger flange may be all that's needed (aside from notching out the bore a bit).
  2. IdahoDon | Nov 15, 2012 08:46am | #3
    I'll bet the original guy who bored the holes simply drilled them 2-1/2 using 2-3/8" hardware....1/8" isn't much and most hardware will cover that.   Depends on your hardware.   If the holes are 2-1/4" and (like some I'm working with this week) the plates on the knobs are only an eigth inch larger then you'd have a hard time.
    Having said that, there's nothing wrong with morticing the bolt plate deeper than usual and adding a thin spacer such as another plate so the actual plate is flush with the door if it looks and functions correctly.   Different mechanisms handle misalignment better or worse so it depends on what knobs you're going to use for replacements.
    Good luck
