Can I use router to mortise hinge & lock on fiberglass door?
bluefox_ | Posted in Construction Techniques on September 2, 2017 11:38am
I have not worked with fiberglass doors previously.  I have had limited experience hanging doors in existing jambs most of my work has been pre-hung units, but I am comfortable taking it on.
Now I have a client that wants an exterior door replaced, and I lean toward just replacing the slab.
If I purchase a fiberglass slab, can I use my router and template to mortise the hinges?
The existing lock is a mortise style lock, which I have never worked with.  Is the strike side stile on a fiberglass door a different material that routes cleanly?  Is it crazy to attempt installing a mortise lock on a fiberglass door?
I have visions of touching a router bit to the door and shredding out long strands of fiberglass and instantly ruining a $500+ slab.
Blue Fox Carpentry
  1. calvin | Sep 03, 2017 10:29am | #1
    Kevin
    Blue Fox Carpentry
    check closely in advance the slab you'll be getting.  All the Fiberglas entry's I've worked with have a wood edge you can rout the hinges and and latch mortise of conventional hardware.  A mortise lock set might have a wider plate.......
    Drilling out the holes in the fiberglass skin would be no problem.
    The rail and stile dimensions should be available from the manufacturer.
Picture-Perfect Pergola
