Can’t find real 2X4’s what do I use?
Senna | Posted in Construction Techniques on August 24, 2004 12:47pm
I am working on a garage and need to replace the sill which has rotted out. The building is built from 2X4’s (not 3.5 X 1.5’s). Can’t find a source for material. What should I do?
Same story last week. Needed to replace some roof boards 1×8’s. Nobody carries them. Solutions?
    dieselpig | Aug 24, 2004 01:14am | #1
    When I have to replace 1x8 roof decking I either use 1x8 rough sawn spruce (spring board) for small areas, or just use rips of 3/4" CDX if I've got more area to cover.
    As far as the 2X4's go... I'm not sure anyone is really even milling them anymore.  Use the nominal 2X4's instead and pack out where you need to.
    If you're really up to it, you could rip and plane your own, but I can't imagine it would ever be worth the hassle unless they were exposed or something.
  2. Hubedube | Aug 24, 2004 01:15am | #2
    Buy some 6 x 6, a table saw, and a planer and make your own.
  3. JohnSprung | Aug 24, 2004 01:28am | #3
    Stack rips of 1/2" ply on top of the new PT 2x4's.
    -- J.S.
  4. maverick | Aug 24, 2004 01:48am | #4
    You are better off replacing the sill with pressure treated lumber and a rip of 1/2" plywood on the top.
    But if you really want nominal 2x4s any local mill will have them although usually not kiln dried. If you go that route staple 30# tar paper to the underside.
    1. Senna | Aug 26, 2004 10:37pm | #5
      It struck me today - why not glue together two 5/4x6's PT and rip that down to 4 inch?
      1. JohnSprung | Aug 27, 2004 02:49am | #10
        Depends on what kind of tree it's from.  If it's Doug Fir, ripping after you glue it up will cut off the shallow treated surface.  Ripping first and gluing to the new surface should work.  SYP we don't have around here, but I've heard that the treatment soaks right thru it.
        -- J.S.
        1. Senna | Aug 27, 2004 04:45am | #11
          What is SYP?
          1. donpapenburg | Aug 27, 2004 05:34am | #12
            Southern Yellow Pine
        2. FastEddie1 | Aug 27, 2004 06:16am | #13
          But if you don't glue them together properly, you end up with the performance of two 5/4x4's rather than a 2x4
          Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
          1. JohnSprung | Aug 27, 2004 08:57pm | #15
            True, but this is a sill plate for a garage.  Horizontal shear isn't a problem.  Stacking a rip of 1/2" ply on top of new PT would work fine, too.
            -- J.S.
          2. kclarson | Aug 28, 2004 01:21am | #16
            How about stacking 2 treated 2x4's and trimming the bottom of the studs which probably have some rot as well? Could fur out the 4" direction with 1/2" ply or rip down a couple treated 2x6's to match stud depth.
          3. FastEddie1 | Aug 28, 2004 04:17am | #17
            I thought he needed studs.  You're right ... for a sill, stack'em with PL and nails.
  5. JonE | Aug 27, 2004 01:30am | #6
    I take it you're not somewhere that has a sawmill or two nearby?  I'd have a local mill cut you some white oak for sills, full 2x4.  Green or dry, they'll last you as long as any PT stuff.  If you're in the middle of nowhere and they've never heard of white oak, good substitutes are black locust (even harder to get), cypress, redwood, or you could even go buy a PT 6X6 and have a local portable mill owner rip it for you.
    Same for the roof boards.  Find a local mill.
    1. Senna | Aug 27, 2004 02:24am | #7
      I called around my local lumber yards. No luck.
      Aren't most sawmills close to the forest the lumber is harvested from?
      I thought my idea of ripping two 5/4's was a good one. I can't cut a 6x6 on my saw, and I don't want to think of the cost of using oak.
      1. FastEddie1 | Aug 27, 2004 02:34am | #8
        Set up infeed and outfeed supports, cut half way through, flip the board over, keep the same face against the fence, and rip again.  People do it all the time.
        Even better, tell the DW you just have to get a bandsaw.  My 14" Delta 1/2 hp will cut a 6-1/2" high board almostr effortlessly.   Bandsaws are fun to use ... almost zero chance of kickback.
          Sphere | Aug 27, 2004 02:39am | #9
          not "almost zero chance of kickback"
          it IS zero..
          he could also use a circ saw and 4 rips to cut a 4x6 into a 2x4..
  6. csnow | Aug 27, 2004 06:20pm | #14
    Not PT, but most lumber yards around here do carry rough cut full 2X8s that could be ripped in half.
    If you do not use PT, certainly create a break between to masonry and the wood to prevent 'rising damp'.  Used to use snow & ice type membrane, but I like the new PVC roll flashing for this.  Thinner than membrane, cheaper than copper, and does not react with the AQT.  Can't remember the brand. Bought it at Lowes.
    If you go with standard lumber, not too difficult to find wood 1/2 inch thick.
    The problem with using plywood to make up the difference is that it is not actually 1/2 inch thick (15/32, or whatever).  Perhaps close enough.
    You could also just place 1/2 inch blocks under each stud instead of a continuous piece.
