Can’t hide a junction box?
woodnoob | Posted in Construction Techniques on February 21, 2007 08:23am
Hi.
I’m doing a bunch of trimwork in a modular home to update the old, hideous look.  It’s not exactly a fine home, but it’s my customer’s home nonetheless, and I want to make it look great for her.
One feature we want to change is the fake oak veneer covered beam running the length of the main living area (21′ long).  I suggested we just cover it over with finger jointed pine trim and paint to match the other trim.  She liked that idea, but the problem is there is a ceiling fan mounted on the beam.  The fan is as tacky as the rest of the trim, and she wants it gone.
Code wont allow me to cover the junction box behind the fan.  Options anyone?  Does anyone know of some decorative covers to hide the box?  Any other ideas?
Thanks everyone.  I’m trying to talk her into replacing it with a modern looking fan, but for whatever reason she doesnt want to.
  1. JMadson | Feb 21, 2007 08:27pm | #1
    Is this fan's junction box a dead end? If so, can you find the other end of all of the wires in the box? If you can find the other end of the wires, pull'm out and cover the box.
    “The richest genius, like the most fertile soil, when uncultivated, shoots up into the rankest weeds..” – Hume
  2. JohnD1 | Feb 21, 2007 09:27pm | #2
    I am guessing that this is a recessed box, and all you have is the cover plate to worry about.
    If this is the case, you have several options:
    • You can take a plain cover plate and paint it or glue paper on it.
    • I have seen cover plates made from wood although I think that they might be unpermissable in some areas.
    • What kind of patch were you going to use to hide the hole?  Just put that patch onto the cover plate, leaving a small opening for the screws.
  3. JohnSprung | Feb 21, 2007 10:33pm | #3
    If it's hot, the box must remain accessible.  If not, you can abandon it in place and hide it.
    -- J.S.
  4. rez | Feb 21, 2007 10:40pm | #4
    You could just put a small unobtrusive light fixture of some sort on there.
    BillHartmann | Feb 21, 2007 10:44pm | #5
    If the box has wires that continue on then it needs to be accessible.
    But if it is just a single switched cable then you can disconnect it at the switch and remove/cover the box.
    If you have power comming in and then a switch leg you need to disconnect the power in and the switch leg at the switch.
    But if either hot or switched hot continuses on to other places it needs to either remain or wired around.
    There are simple plain white round plastic covers for ceiling boxes.
  6. Piffin | Feb 22, 2007 01:58am | #6
    If this is just a dead end mounting box, it is not a junction box and if you disable the power to it, then you can lose it.
  7. User avater
    xxPaulCPxx | Feb 22, 2007 02:36am | #7
    If the area above it is attic, you can remove the box, pull the wires up into the attic, and remount a new box up there out of the way as long as it can still be easily found again.
    Also a CRX fanatic!
  8. woodroe | Feb 22, 2007 03:45am | #8
    If you need one, there is a UL approved "splicer" for romex that requires no junction box. You should be able to get one from an electrical supply house.
      BillHartmann | Feb 22, 2007 06:29am | #13
      "If you need one, there is a UL approved "splicer" for romex that requires no junction box. You should be able to get one from an electrical supply house."They are only for specialized applications (modular homes?) and they still need to be accessable..
    2. IdahoDon | Feb 22, 2007 06:33am | #14
      I've never heard of this before.   NEC allows it?  What kind of splicer is it?  How new does the wire have to be?  Anyone have a specific part number?  How expensive?  Interesting.
  9. alwaysoverbudget | Feb 22, 2007 04:21am | #9
    great place for a smoke detector or a co detector.larry
    1. brownbagg | Feb 22, 2007 05:18am | #10
      I was told you could hide a junction box as long as it is accessable. It be like having a box in the attic. Its there and nobody can see it but you can get to it, if you have too.You cant hide one in a wall with no way to get to it, but you can to the whirlpool tub as long as there a panel to it
    2. brownbagg | Feb 22, 2007 05:19am | #11
      or screw an HVAC vent over it
      1. brownbagg | Feb 22, 2007 05:20am | #12
        if you made an permant splice in the box, would it then be a junction box?
        1. FrankDuVal | Feb 22, 2007 07:05am | #15
          if you made an permant splice in the box, would it then be a junction box?Yes!Frank DuVal You can never make something foolproof because fools are so ingenious.
  10. User avater
    maddog3 | Feb 22, 2007 03:57pm | #16
    I hope you"re not using a neon type tester ......
    , wer ist jetzt der Idiot ?
  11. karp | Feb 26, 2007 11:55pm | #17
    Couple of options
    1) dome cover plate, very common, install a bar and centre decorative nut
    2) As mentioned, dissconect the switch leg and lose it
    3) Electrician once buried a box by soldering the wires, said it was to code, I never checked cause I just wanted to get rid of the box. Wouldn't recomend this for multiple wires, but a straight junction, why not? Oops shouldn't have said that, now I'm in for it.
  12. cap | Feb 27, 2007 12:07am | #18
    disco ball
    white suite wide lapels
    strike da pose
