Capping “W” flashing at ridge?
CamSweet | Posted in General Discussion on November 18, 2011 10:38am
All,
I have a valley that meet, just a foot short of the ridge of a perpendicular roof. I have run w flashing to the top of the lwer ridge but would like ideas on how best to cap it off ro prevent leaks. WHat’s everybody doing?
Thanks,
Cam
    xxPaulCPxx | Nov 18, 2011 01:20pm | #1
    I used a piece of metal flashing as a single that comes off the top roof centered on the lower ridge. After it comes out flat on top of the ridge, you bend over the corners to cover the top of the W metal.
    1. MikeSmith | Nov 18, 2011 05:01pm | #2
      cam
      the ridge cap from the  minor  ridge is  going to  transition across the intersecting  W-valley
      metal, Grace  and  caps will make it waterproof..it  all has to die into the  major ridge cap detail
      interesting  how  new your sheathing  looks  under those old  existing  roof shingles
  2. Piffin | Nov 19, 2011 01:36pm | #3
    When installing the W valley material, if you cut and flold that top joint carefully it doesn't need anything else.
    But where there is concern, some guys ue a piece of lead sheet to work over that joint, since it is flexible
