Carbon Fiber Strips for walls
rdmhome | Posted in Construction Techniques on October 11, 2008 07:03am
A customer of mine has a basement cinder block wall that is bowing inwards about 5 inches.
After straightening, will the bonding of vertical carbon fiber strips do anything to cause the wall to stay in the vertical position??
Anybody have any experience with bowing cinder block basement walls??
Come on back……..
Bob
  1. highfigh | Oct 11, 2008 07:22pm | #1
    By 'strips', what are their dimensions, how would you attach them and what will be the orientation, relative to the wall's surface.
    Why carbon fiber?
      rdmhome | Oct 11, 2008 07:30pm | #2
      Highfigh,
      The carbon fiber strips commercial name is "The Reinforcer".
      See website:
      http://www.thereinforcer.com
      The strips are 4 inches wide and about 1/4" thick and epoxied to the wall from floor to ceiling.
      Any help?
      Come on back...
      Bob
      1. iluvgear | Oct 11, 2008 07:52pm | #3
        No "strips" are going to correct that problem.  My experience is that bowed basement walls are being pushed; that usually involves water.
      2. highfigh | Oct 11, 2008 08:17pm | #5
        This would involve digging outside of the wall, straightening and then installing the strips, right? Leaving the bow, you can't bend the strips in a way that they would do any good. Also, 4" is only 2" less than most of the steel I have seen installed and if you're in a cold area, using steel will allow you to use more insulation. I have a friend who just bought a house with a bowed wall and they corrected it using steel. I looked at one last year too, and the flange helps to ensure that the steel won't tip if the forces exceed what the resistance to bending can resist.
  2. DanH | Oct 11, 2008 07:57pm | #4
    In theory it could work, but I have my doubts in practice, and it would be highly dependent on the skill of the installer in any event (not to mention the condition of the block).
    Things that work:
    -- "Deadman" anchors
    -- Vertical steel beams every few feet
    -- Opening up the top of the wall to install rebar and grout the cores
    Corporation: n. An ingenious device for obtaining individual profit without individual responsibility. --Ambrose Bierce
    jonblakemore | Oct 11, 2008 09:30pm | #6
    We have not installed the reinforcer strips, but I know a very reputable contractor in the area who does install them.
    I think that it can be a very good system, assuming you address the cause of the original problem.
    I would look at the grading of the home first. Do you have 6" of fall in 10' all the way around the house? Do the gutters (if the house has gutters) lead water away from the foundation, or are they dumping it right at the foundation wall? Are there functioning footer drains?
    I do think that water is typically at the root of foundation wall problems like your customer is seeing.
    Once you've corrected the problems, the strips are a good solution from what I know about them. In order for a wall to bow inward, the original straight line of the foundation wall needs to become a curve. Affixing a high tensile strength "strap" to the inside face will help keep things in check.
    Have you contacted the manufacturer of "The Reinforcer"?
    Jon Blakemore
  4. MikeHennessy | Oct 14, 2008 03:23pm | #7
    I've had a couple of clients with similar problems -- I sent 'em to a contractor who specializes in this. He uses kevlar strips bonded to the inside wall with epoxy. So far, all have been pleased with the results. It ain't cheap tho'. Also, never treat the symptom without treating the underlying disease, namely fix the drainage issues outside the foundation no matter what interior fix you go with.
    Mike Hennessy
    Pittsburgh, PA
    Edited 10/14/2008 8:24 am ET by MikeHennessy
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
