Looking for a carpenter and/or trim carpenter to do work on home. Located in the Northwest surburbs of Illinois.
please reply to [email protected]
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
hi im open with some free spots .what do you have to do?and where are you at?lets talk.email at [email protected]
Try sending another reply, only this time, at the bottom of the reply screen, click the button that states 'Reply via e-mail' An e-mail will be sent thru Breaktime, so you don't have to wait until he logs onto BT to read it.
And welcome to BT. If you haven't already, fill out your profile.
