CARPENTER’S GLUE SOLVENT
| Posted in General Discussion on August 4, 1999 07:28am
I am looking for ideas on how to soften wood glue. I have oak dining chairs. Legs have been glued, pinned, and clamped. They need to come apart and be re-done.(Long story so don’t ask why)I know that carpenter’s glue is harder than nails when it’s set and have accepted the fact that this ain’t gonna’ be easy. Any thoughts?
  1. Dan_Bittner | Aug 04, 1999 07:28pm | #1
    I am looking for ideas on how to soften wood glue. I have oak dining chairs. Legs have been glued, pinned, and clamped. They need to come apart and be re-done.(Long story so don't ask why)I know that carpenter's glue is harder than nails when it's set and have accepted the fact that this ain't gonna' be easy. Any thoughts?
  2. Guest_ | Aug 04, 1999 07:28pm | #2
    If you've used aliphatic resin (yellow glue), you can take it apart with heat and/or steam. I've seen rigs made from a steam kettle that direct the steam through a reinforced tube capped with a needle valve - the type used to inflate soccer or basketballs. Steam works for white glue and hide glues as well, I think.
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
