Anyone have a link to a site for cast-iron cutting recip blades?
wouldn't cast iron blades be kind of brittle?
Thank you.
you are quite welcome
Barry E-Remodeler
http://www.amazon.com/Milwaukee-48-00-1430-Tungsten-Carbide-Sawzall/dp/B00004U0U2
Had a Plumber / boiler fitter out at the last job, he was goin thru CI like a hot knife. I saw it was a Lennox blade, which I have, and assumed it was the same.Fire and Rescue type..Nope. It was a new metal cutting blade. At Lowes I saw they have three different ones for various thicknessess of metal. I had to cut a pipe holding a meter base , so I bought a medium cut. 5 actually...ane whoowheee, sweeeet. Try Lowes.
I've got to make a bunch of cuts in 4inch sewer stack.
You have a specfic name for the one the boiler guy was using?
94969.19 In the beginning there was Breaktime...
We use grinders with abrasive cut off discs. Much less vibration, less likelyhood of causing a leak/break up or down the stack.
Abrasive blades work great. Sometimes you can't get the saw on both sides so you might have to finish up with something else. Grinder?
Been using them more and more lately for all kinda different things....not to mention those wheels are real cheap.
Did a big bathroom job and had to cut a ton of cbu's. Took all my measurements and went outside and cut all my cbu's with my grinder. Quick, clean, easy .....
and cheap.<--( I know someone like Sphere's gonna make a crack about that.....let'r rip...lol)
BTW...I used to live in Queens myself...I'm in the Huntington area.
http://www.ramdass.org
Yeah, the grinder is kinda priceless working in NYC buildings...lots of plaster/mudbeds that are a mile deep with mesh embedded...grind away! Hammering/prying/peeling almost always causes problems for the tile/plaster in the nextdoor/downstairs unit.
Lemme run out in the van..Spheramid Enterprises Architectural Woodworks
Lenox Lazer Metal 9114R 14T Bimetal for med and thick. 9'' long.
From the ManufacturerThe new Lenox Laser Recip. Blade is designed to cut pipe, structural steel and stainless steel. The patented tooth design increases blade life and cutting speed. The Laser blade is 40% wider for even greater strength, durability and straight cutting. This blades is ideal for vehicle extrication and emergency work.
Edited 12/28/2008 4:36 pm ET by Sphere
Edited 12/28/2008 4:37 pm ET by Sphere
Cool beans, I get to go to Lowes again. Thanks.
There's a big pile of culled sitting there I was talking to the manager about before the last storm hit.
Was discussing what all was to be added to it. snorK*
Does Lowes have a 12 step program ??!!??
>> I get to go to Lowes again.<<
You get banned from Lowes?
Every car, truck and tractor in America should run on natural gas- it's the future.
if he did, I do NOT wnat to know why
I refuse to accept that there are limitations to what we can accomplish. Pete Draganic
Take life as a test and shoot for a better score each day. Matt Garcia
See if you can rent or borrow a cast iron snap cutter and save yourself some trouble
Barry E-Remodeler
ya, just spent a half hour searching thru old castiron cutting threads here on BT and figgered the blades will fit this project better.
Thanks.
I had a homeowner buy me a blade to cut this 60 year old plaster that ate about four of my very best blades in 45 minutes. She comes back from lowes with one for masonry, it had grit instead of teeth, and I think that there were diamond specs in it. That thing was an animal, two of those blades finished that job, and I must have spent at least three days cutting into that plaster. I THINK that Lennox made it, and I'm pretty sure that the package said it could cut iron. Like the last guy said, just cruise around Lowes, your bound to find something that will work.
And about Harbor Freight, they are what they are. I don't buy any blades from them, I learned that lesson a long time ago. I did get a paper from them with a button-cap stapler for less than $100, and we have yet another roofing job coming up so I'm very tempted to buy it. Some of their air tools are OK, but its a gamble every time you go in there. Somebody please talk me out of that button-cap stapler!
Edited 12/29/2008 6:10 pm ET by arcflash
Lennox makes a circular saw blade for cutting steel. it has carbide teeth and it does an amazing job. about $80 iirc
Good recommendation....but WHOAAAA!!
I'm just not sure REZ can drive a loaded cull cart through the tool dept. ..... ;>)
Bill
Well there are these
http://www.lenoxtools.com/enUS/Product/Diamond___Recip_Blades.html
But you can answer a questionnaire and get a T2 blade free.
http://www.cutsomething.com/lenox/sampleBlade/index.jhtml?_requestid=176890
Edited 12/28/2008 10:11 pm ET by reinvent
YA gotta love idiots like Lennox. They don't know that Alaska is a state!
We'll see what happens with a AL state but an Alaska address.
Just wish we belonged
any quality metal blade will do. I tried craftsman once and they lost teeth faster than a kentucky boy in a bar fight.
then I tried milwaukee and cut like butter.... well, very hard butter but it worked nonetheless
I was on a mudset and wire mesh high rise job with a guy. He was so proud of his harbor freight blades that he got a smoking good deal on, I finally got impatient after we burned up the 6th blade without making any headway and went down to the truck to get an old milwaukee torch blade to finish it off. Frustrating when people waste so much time trying to save money that they cost you more in the long run.
I made up my mind a long time ago to avoid saving a few bucks and sacrificing quality... tools, stuff around the house and even food.... it is seldom worth the savings.
Last time I cut cast iron was about 12 years ago. Used a Lennox blade for cast iron. If I recall took about 15 minutes to cut 4". Cut was clean, slow but sure.
mike
