Cast iron sink
poppi | Posted in General Discussion on February 2, 2006 08:01am
I am in the process of demolishing a kitchen. One of the few remaining tasks is removal of an undermount cast iron sink (33x22x8). Anyone have any idea what this baby will weigh? My wife is concerned about my back.
Thanx, john
  1. BobKovacs | Feb 02, 2006 08:24pm | #1
    I'm thinking it won't be more than around 40-50 lbs, if that.   The biggest PITA will be supporting it while unfastening it from the countertop, and then muscling it out of the cabinet.  If you're not salvaging the cabs and/or top, a few good whacks with an 8-lb sledge will quickly reduce it to manageable pieces (and relieve some agression at the same time).  Just be sure to wear safety glasses, as the porcelain flies everywhere.
    Bob
    Ricks503 | Feb 02, 2006 08:38pm | #2
    I removed one from our old house a couple of years ago and if it is like mine, I bet it will tip 60-80lbs (felt like 100 lbs to my back though). And it is a bear to manhandle alone.
    1 - measure the board twice, 2 - cut it once, 3 - measure the space where it is supposed to go        4 - get a new board and go back to step 1
  3. deskguy | Feb 02, 2006 09:37pm | #3
    John,
    Think I saw this somewhere?  cut a 2x4 about 28-30 inches wide  cut another about 6-8 inches wide.  place the longer board on top of the sink front to back using the counter to support it.  Tie a rope around the smaller board and feed the rope up through the drain hole and tie the rope to the board above.  You should be able to detach the sink from below, then slide out, stand up, twist the top board and lower the sink into the cabinet.
    fengelman | Feb 03, 2006 01:46am | #4
    all the cast iron undermount sinks I've ever seen are really suppported by the cabinet, not the counter...but they still weigh a ton..
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
