Read article in June/July issue.
My roof composition is considerably different.
Have (from outside to inside….
Roofing (maybe dark asphalt or standing seam steel)
3/4″ air gap (fully ventilated )
Radiant barrier
2×6 rafter
10 Mil plastic moisture barrier
1/2″ greenboard.
We live in the Kansas City area.
Will this configuration have any moisture or mold issues ?
I don't think it would have any moisture problems. You don't say what type of insulation you are using, but if the 10 mil vapor barrier is installed correctly, it should stop vapor before it gets to the insulation. So any type of insulation should be okay. The air gap ventilation will act as a backup measure to dry out any vapor that happens to get past the vapor barrier.
If you are using closed cell spray foam for insulation, many will tell you to omit the vapor barrier. I would retain the vapor barrier no matter what type of insulation I used.
Well, there is a significant difference between black asphalt shingles and standing seam metal... which do you have?
Your air gap and radient barrier are a little wonky as well.
Here is what I would expect to see, based on the ingrediants you list:
Asphalt Shingles
Tar paper (or Synthetic) underlayment
Radiant Barrier sheathing
1x Furring providing air gap beween continuos soffit vent and ridge vent
OSB/plywood deck (which I would tape the seams and put Tyvec/TYPAR on myself)
2x6 rafters
R19 fiberglass insulation between the rafters
plastic sheet moisture barrier
Drywall (unless it's a bathroom, why use greenboard?)
