Cathedral ceiling insulation options
I know, I know, this topic is beaten to death here. However, I searched and am still uncertain which options are best, so I thought I’d add another discussion.
1500 sq ft of cathedral ceiling. 2×6 depth (sistered to 2x4s). No soffits or roof venting possible. Kansas City.
First bid came in at $6200 for full depth fill of open cell foam. This is contrary to all research I’ve read that says open cell would be a bad choice because of moisture issues in the winter. Also, this yields a lower R value than other options.
Second bid came in at $6800 for one inch of closed cell, with the rest of the depth blown in fiberglass or cells. This yields R24, but research suggests that half of the R value should be closed cell. (buildingscience.org article)
I started looking at DIY solutions using Foam It Green or Tiger Foam, or rigid foam, in combination with batts. I could spray 2″ of closed cell and add R13 batts for a total of R26.4 for around $3600 or so.
Thoughts on acceptability of this solution over other combinations? For example, foamed in rigid foam plus spray, or cc plus oc spray, etc.
Thanks for your time.
Need to clarify ... 2x6 and 2x4 ... that would be 9inches deep, right? Traditional high density fiberglass batts would be R-33 or better (R-21 and R-13). Any uses of foams should increase that as the foams should have higher R per inch. FYI I'm not much of a foam expert particularly w/ the newer stuff on the market. You could do all fiberglass or cellulose ... install a good vapor retarder AND ensure any and all penetrations are detailed properly (or eliminated if possible). One good way of controlling the moisture element is to ensure that the vapor retarder is continuous so the moisture doesn't get into it to begin with.
Others will chime in with more food for thought, I'm sure.
