Cathedral cieling insulation
| Posted in General Discussion on May 3, 2000 03:52am
I would like to insulate the ceiling of the Breezeway between my house and my garage but am having trouble with the air flow issue. The roof rafters are 2×6 and there is no soffit as the facia is nailed directly to the solid block walls. The house was built about 1945 in the Tudor style. Should I use a ridge vent and if so where will the air come from? If anyone has a solution I would be most appreciative.
Reed
  1. Reed_Ellis | May 03, 2000 03:52am | #1
    I would like to insulate the ceiling of the Breezeway between my house and my garage but am having trouble with the air flow issue. The roof rafters are 2x6 and there is no soffit as the facia is nailed directly to the solid block walls. The house was built about 1945 in the Tudor style. Should I use a ridge vent and if so where will the air come from? If anyone has a solution I would be most appreciative.
    Reed
  2. Guest_ | May 03, 2000 03:52am | #2
    can u take off the fascia and extend the rafter and create a continuously vented soffit connected to a Shingle VentII ridge vent?
