Caulk on Crown
JMadson | Posted in General Discussion on October 2, 2005 04:03am
Recently installed white painted 4″ crown in a pre-painted family room. The customer would like to have the caulk on both the top and bottom to eliminate any and all gaps. On the top, it’s no problem because the crown and the ceiling are both white – the caulk blends right in.
But on the bottom, the walls are a dark tan. When I apply the caulk, I’m having a difficult time keeping too much of the caulk off of the tan paint and also keeping a straight line. Does anyone have any tricks on handling this situation?
thank
Joe
  1. DRoss | Oct 02, 2005 04:10am | #1
    sometimes you can mask off the walls.  or else re-paint them
    1. JMadson | Oct 02, 2005 04:16am | #2
      I'm doing everything to avoid repainting. Blue tape will work?
      1. DRoss | Oct 02, 2005 04:24am | #4
        sure, i'd use some type of painters tape, but i'd make sure the caulk was fully cured before i removed the tape. also , if you cut the tip of your caulk too big you'll have nothing but problems.  use as little as possible, and angle your tip right into the joint.  you might even get away without having to mask.
    basswood | Oct 02, 2005 04:20am | #3
    Try a fine bead of paintable clear ALEX. It goes on white and turns clear. The clear caulk "picks up the color of the wall" and minimizes gaps. If that is not enough for the customer, it can be painted in either wall or crown color.
  3. HeavyDuty | Oct 02, 2005 04:36am | #5
    Tape the wall right up to the bottom of the crown, a bead of white latex caulk lightly smoothed with a half wet sponge sanding block, take the tape off at the right time and you shouldn't have to do any touch-up. Depends on the size of the gap you may have to do it more than once.
    Depending how meticulous the client is, some original touch-up paint just in case.
    Any low-tack tape will works.
  4. gbwood | Oct 02, 2005 04:41am | #6
    I spend a couple bucks more for "Polyseamseal" brand caulk- it tools off much nicer.
    greg
  5. DougU | Oct 02, 2005 04:42am | #7
    What TomC says
  6. CAGIV | Oct 02, 2005 04:53am | #8
    Try laying a thin bead of  Alex or equivalent, tool it with your finger smooth, and wipe it down a few times with a damp sponge.  I've had good luck with it in the past.
    Team Logo
  7. User avater
    skyecore | Oct 02, 2005 07:43am | #9
    I prefer to take the tape off when the caulk is still wet for 2 reasons:
    1. if any caulk snuck undernieth the tape you will find it while still wet and be able to clean it, and..
    2. If you pull the tape off afterward, there will be a small and ugly line where the caulk met the tape which will be dried in place.
    If you take the tape off while the caulk is still wet simply run a damp finger back over once tape is removed to make a smooth transition from crown to wall..
    Personally i'd say **** the tape, faster to just use as little as possible (as mentioned before) and any accidents you will be prepared for with a damp cloth.
    ______________________________________________
    --> measure once / scribble several lines / spend some time figuring out wich scribble / cut the wrong line / get mad
  8. User avater
    JeffBuck | Oct 02, 2005 08:35am | #10
    caulk then paint.
    fact of life and fact of remodeling.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. JMadson | Oct 02, 2005 09:15am | #11
      Awesome advice, thanks all.
      Joe
      1. Shep | Oct 02, 2005 02:24pm | #12
        If the crown still needs to be painted, I use a caulk that closely matches the wall color. Just make sure not to leave a lot on the wall, because the sheen will probably be different.
        For a tan wall, I'd use an almond or cedar colored caulk.
        1. JMadson | Oct 03, 2005 07:38pm | #13
          Finished the touch-up work this morning. I ended up using the brown painters tape, about 6' at a time. This is as far as I can reach when on the ladder. I went right up to the crown with the tape and applied the caulk. Smoothed it with my finger and then pulled the tape off. Made a perfect line with very little mess. Finished a 12'x12' room in about 30-40 minutes (it took most of my time to move the furniture around).
          Joe
Grout-Free Shower Panels
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
