Caulk won’t dispense – no, it’s not the foil seal !
jackfiasco | Posted in General Discussion on April 2, 2020 09:57pm
Have a tube of silicone.  I bought it 3 years ago, but it was sealed.  Recently I cut the tip off, punctered the seal (could smell the vinegar smell of the fresh silicone), but then realized I didn’t have a gun.  I tried sticking a hammer in the end and pushing it forward.  No dice.
So I wrapped plastic wrap around the tip and bought a gun a few days later.  Put it in the gun just now and it feels like I’m trying to dispense hardened cement.
I put a skewer down the nozzle end and it easily goes all the way through and comes out with silicone on it.  It’s certainly not dry.  I can also squeeze the tube and it gives.
So I took a knife and stuck it in the back and went all around, thinking maybe some silicone dried there and is keeping the back from pushing forward.  I did that twice.  Still nothing.
What the hell?  This mystery is blowing my mind.  The gun works fine, and is brand new, by the way.
What’s going on?  Do I have a haunted tube of silicone?  Is it like, half dried out? Enough that it won’t move, but not so dried out that I still see and smell fresh silicone when I poke a stick down in there?
  1. oldhand | Apr 02, 2020 10:03pm | #1
    3 years is pretty long for silicone shelf life. Could be it has a little bit inside not cured but too much cured to allow it push out.
    I assume you're not just funnin' here...
  2. DanH | Apr 02, 2020 10:10pm | #2
    Figure out how to give the piston end a good whack. Sometimes the piston glues itself to the sides of the cylinder.
    sawdust_steve | Apr 03, 2020 08:10am | #3
    Make sure it's warm enough. I just went through hell trying to apply poly adhesive on a cold day.
    Brought the tubes in overnight and the next day it was as smooth as butter.
  4. florida | Apr 03, 2020 08:52am | #4
    Caulk is not eternal, even in the tube. It's hardened up, throw it away and don't buy a new tube unless you're building a fish tank.
  5. jackfiasco | Apr 03, 2020 10:03pm | #5
    Got it. Thanks all.
